Старый 15.12.2009, 03:23   #1
25,644 / 848 (80) +++++++
lcash: Project Time Sheets Period Code
Источник: http://blogs.msdn.com/lcash/archive/...riod-code.aspx
I’ve had a few questions on this and posted a few notes on using Project Time Sheet on the demo VM. Scott and Kathy from the dev team helped and pointed out the issue with the period codes that we have setup in the demo data.
The issue is inconsistency in showing up the day data entry fields on the Enterprise Portal on the demo VM. The fix is to create a new period code and associate that with the user you are working with. For example in the demo data Prakash who is the project manager you’ll intermittently get the day fields to show. This video will walk you through the steps.
(double click to watch full screen)
Thanks Scott and Kathy.
Cheers
Lachlan
Original post at http://blogs.msdn.com/lcash
lcash: Project Time sheet entry Blog bot DAX Blogs 0 01.12.2009 21:05
lcash: Using Project Time Sheets setting up the Period Code Blog bot DAX Blogs 0 31.07.2009 06:16
AX UK: Project Time Management for Microsoft Dynamics AX 2009 - Beta Blog bot DAX Blogs 0 12.12.2008 12:05
Malaysia: How to Run Time Add Code to AOT Blog bot DAX Blogs 0 18.09.2007 15:00
Часовой пояс GMT +3, время: 16:33.
