Старый 22.12.2010, 08:53   #1
Vadik is offline
Vadik
Аватар для Vadik
3,631 / 1849 (69) ++++++++
The Connector for Microsoft Dynamics
Integration between Microsoft Dynamics CRM and another two global Dynamics ERP products has arrived with the release of Feature Pack 4 of the Connector for Microsoft Dynamics!
Customers of Microsoft Dynamics AX and Microsoft Dynamics NAV now have access to the same simple, reliable and extendable integration with our CRM product that we shipped for GP earlier this year (Formerly known as Microsoft Dynamics CRM 4.0 Adapter). Out-of-the-Box entity mappings provide immediate value by integrating the key data in both systems. That basic integration can be extended by adding new maps, or leveraging the SDK to create custom integrations.
The Connector is ready for use today!
On Feb. 1, we will provide additional customer-facing materials as a part of the formal product launch, which will also include integration to CRM 2011 online.
Ссылки на Partnersource
Connector for Microsoft Dynamics Feature Pack 4 for Microsoft Dynamics AX 2009
-ТСЯ или -ТЬСЯ ?
Старый 17.03.2011, 15:44   #2
Poleax is offline
Poleax
Аватар для Poleax
1,353 / 595 (22) +++++++
Записей в блоге: 34
Partnersource: Connector for Microsoft Dynamics Feature Pack 5 for Microsoft Dynamics AX 2009
Дата изменения 02.02.2011
Отправлено 14.12.2010
The Connector for Microsoft Dynamics Feature Pack 5 provides an integration between Microsoft Dynamics CRM 4.0 (minimum Update Rollup #5) or Microsoft Dynamics CRM 2011 and Microsoft Dynamics AX2009 SP1.
The downloadable Connector on this web page is specifically designed to integrate Microsoft Dynamics CRM 4.0 or Microsoft Dynamics CRM 2011 to Microsoft Dynamics AX2009 SP1.
***Please note – It is important to note that setup and configuration expertise are critical to a successful deployment of this tool.
Overview
The Connector for Microsoft Dynamics is an integration solution which is targeted specifically at the Microsoft Dynamics family of products.
The primary emphasis of the Connector is that of simplicity and ease of use while providing highly reliable and fault tolerant business document integration between Dynamics family products.
The Connector for Microsoft Dynamics SDK contains documentation, templates, and sample code to help third party developers and partners who want to extend the functionality of the Connector for Microsoft Dynamics.
Ordering
The Connector for Microsoft Dynamics is now included in Dynamics BRL Advanced Management Foundation Pack.
To activate the Connector for Microsoft Dynamics AX AM BRL, access your VOICE account where a Registration key is provided to enable activation of the connector in the Adaptor section of your VOICE account.
If you have questions regarding the above, please contact your local Microsoft Dynamics Regional Operations Center. Refer to the link below for support options: https://mbs.microsoft.com/partnersourceapp/chatnow.aspx
System Requirements
  1. Microsoft Dynamics AX2009 SP1.
  2. Microsoft Dynamics AX 2009 SP1 Hotfix for KB2414338.
  3. Microsoft Dynamics AX2009 AIF Web Services.
  4. Configure IIS 7 to host WCF Services (only required if installing the AIF on Windows Server 2008)
  5. Import ConnectorForMicrosoftDynamics.xpo file.
  6. AIF Web Site added.
  7. Microsoft Dynamics CRM 4.0 with minimum of Update Rollup 5 or Microsoft Dynamics CRM 2011 must be installed.
Installation Instructions
  1. Download and review the MSDAdapterFP5 - AX Known Issues.docx document.
  2. Download and review the ConnectorForMicrosoftDynamicsFeaturePack5.pdf.
  3. Download and install Update Rollup 5 or the latest patch release for Microsoft Dynamics CRM 4.0 (only if using Microsoft Dynamics CRM 4.0).
  4. Download and install the Connector for Microsoft Dynamics AX.msi.
  5. Refer to the ConnectorForMicrosoftDynamicsFeaturePack5.pdf for steps to configure AX2009 to work with Connector for Microsoft Dynamics.
  6. Refer to the ConnectorForMicrosoftDynamicsAXFeaturePack5.pdf for steps to help get existing data synchronized.
  7. If you have an existing version of the Connector for Microsoft Dynamics installed, you can install the Connector for Microsoft Dynamics Feature Pack 5 without first uninstalling the existing version.
  8. Note: To ensure proper integration, Microsoft Dynamics CRM and Microsoft Dynamics AX must be in the same locale (with the same base language, base currency, and other base field values).
Downloads
We recommend that you contact your Microsoft Dynamics Partner before installing service packs or hot fixes. It is important to verify that your environment is compatible with the service pack(s) or hot fix(es) being installed. A service pack, hot fix, or download may cause interoperability issues with customizations, and third-party products that work with your Microsoft Dynamics solution.
За это сообщение автора поблагодарили: kornix (1).
Старый 17.03.2011, 16:49   #3
MikeR is offline
MikeR
MCT
Аватар для MikeR
1,628 / 627 (24) +++++++
Жить модулю crm осталось не долго...
Axapta book for developer
Старый 17.03.2011, 17:42   #4
kornix is offline
kornix
414 / 146 (5) +++++
Сообщение от MikeR Посмотреть сообщение
К сожалению видел только сильно кастомизированный модуль CRM, но впечатления от новости такие:
"CRM! Там есть большая таблица, многополевая, событийная.. как газета "Новости" А теперь можно к газете подключиться через bc.net, и читать ее из других приложений"
ax2009, crm, интеграция
Developer for Microsoft Dynamics AX Certification Roadmap Blog bot DAX Blogs 1 13.05.2009 16:17
Сергей Герасимов: Что нового в Microsoft Dynamics AX 4.0 Blog bot DAX Blogs 0 16.01.2007 11:00
Часовой пояс GMT +3, время: 14:29.
