23.04.2011, 07:11 | #1 |
kranthiax: Updating The vendTrans Table
Источник: http://kranthiax.blogspot.com/2011/0...ans-table.html
============== Hi the below code help you to insert custom created field values from a journal(LedgerJournalTrans) to the vendTrans table. The insertion and updation of the vendTrans fields is done with the help of CustVendTrans Map Follow the below setups when you add a new field to the ledgerJournalTrans and update it to vendTrans table... 1. Add the field to the custVendTrans Map - before that add field to ledgerJournalTrans and vendTrans. 2. Create a new mapping in the VendTrans of custVendTrans Map CustVendTrans.ProjId == VendTrans.ProjId 3. Class - CustVendVoucher In the Class declaration add a variable ProjId updateProjId;///Kranthi 4. Add a new method to CustVendVoucher class ProjId parmUpdateProjId(ProjId _projId = updateProjId) { ; updateProjId = _projId; return updateProjId; } 5. In the initCustVendTrans methid of CustVendVoucher class add this line custVendTrans.ProjId = updateProjId; 6. Class - VendVoucher -> in the newVendVoucherJournal method of vendVoucher class place the below line of code vendVoucher.parmUpdateProjId(_ledgerJournalTrans.ProjId); 7. Compile the two classes Hope this code will help you... Источник: http://kranthiax.blogspot.com/2011/0...ans-table.html
Опции просмотра | |
