21.11.2013, 19:11 | #1 |
crminthefield: Automate creating a CRM 2013 Redist folder to install CRM 2013 without an internet connection
Источник: http://blogs.msdn.com/b/crminthefiel...onnection.aspx
============== We’re back for another round of using PowerShell to automatically create a Redist folder, but I’ve recently updated it for CRM 2013 (you can find the 2011 version here and for more information on the 2013 downloads go to our other blog post here which lists each file with the detailed download URL). You’ll notice there’s a couple of new pre-requisites and a couple that are no longer needed. Simply take the script from the bottom of the post and paste it into a PowerShell console on a computer that has internet access, it will prompt you for a location to create a “REDIST” folder, it will also automatically create all the subfolders and download all the pre-requisites for you. Once completed this Redist folder can be dropped into the files extracted from the CRM 2013 Trial download – this step will allow the installation to use locally downloaded pre-requisite installation files instead of downloading them from the internet which can save time and is required for installing the CRM Server bits on servers that do not have direct internet access. Instructions on how to use PowerShell to build your CRM 2013 Redist Folder:
Download the PowerShell Script as a .txt file. Sean McNellis Follow the conversation: @seanmcne @pfedynamics | http://www.pfedynamics.com PowerShellCreateRedistFolderCRM2013.txt script: #begin Script #Function to Show an Open Folder Dialog and return the directory selected by the user. function Read-FolderBrowserDialog([string]$Message, [string]$InitialDirectory) { $app = New-Object -ComObject Shell.Application $folder = $app.BrowseForFolder(0, $Message, 0, $InitialDirectory) if ($folder) { return $folder.Self.Path } else { return '' } } #download pre-req function, also creates the folders function dlPreReq($root, $folderName, $fileName, $url) { $fldr = Join-Path -Path $root -Child $folderName $dest = Join-Path -Path $fldr -Child $fileName #create folder if it doesnt exist if((Test-Path -Path $fldr) -ne $True) { New-Item -Path $fldr -ItemType directory | out-null } Write-Host ("Downloading {0} to path: {1} " -f $fileName, $fldr) $wc = New-Object system.net.webclient $wc.downloadFile($url,$dest) } #download each pre-req function Create-CRM2013Redist() { $linkRoot = "http://go.microsoft.com/fwlink/?LinkId=" $langCode = "ENU" $LHex = 0x409 #must match above langCode $folderRoot = (Read-FolderBrowserDialog "Pick the location to create the Dynamics CRM 2013 redist folder") #folder root if(($folderRoot.length) -gt 0) { $fr = Join-Path -Path $folderRoot -Child "Redist" dlPreReq $fr dotNETFX "dotNetFx40_Full_x86_x64.exe" $linkRoot"182091&clcid="$LHex dlPreReq $fr dotNETFX "NDP40-KB2600211-x86-x64.exe" $linkRoot"299426&clcid="$LHex dlPreReq $fr WindowsIdentityFoundation Windows5.2-KB974405-x86.exe $linkRoot"200432&clcid="$LHex dlPreReq $fr WindowsIdentityFoundation Windows5.2-KB974405-x64.exe $linkRoot"200430&clcid="$LHex dlPreReq $fr WindowsIdentityFoundation Windows6.0-KB974405-x86.msu $linkRoot"190775&clcid="$LHex dlPreReq $fr WindowsIdentityFoundation Windows6.0-KB974405-x64.msu $linkRoot"190771&clcid="$LHex dlPreReq $fr WindowsIdentityFoundation Windows6.1-KB974405-x86.msu $linkRoot"190781&clcid="$LHex dlPreReq $fr WindowsIdentityFoundation Windows6.1-KB974405-x64.msu $linkRoot"190780&clcid="$LHex dlPreReq $fr SQLNativeClient sqlncli_x64.msi $linkRoot"178252&clcid="$LHex dlPreReq $fr SQLSharedManagementObjects SharedManagementObjects_x64.msi $linkRoot"293644&clcid="$LHex dlPreReq $fr SQLSystemCLRTypes SQLSysClrTypes_x64.msi $linkRoot"293645&clcid="$LHex dlPreReq $fr ReportViewer ReportViewer.exe $linkRoot"193386&clcid="$LHex dlPreReq $fr SQLExpr SQLEXPR_x86_$langCode.exe $linkRoot"179623&clcid="$LHex dlPreReq $fr SQLCE SSCERuntime_x86-$langCode.exe $linkRoot"253117&clcid="$LHex dlPreReq $fr SQLCE SSCERuntime_x64-$langCode.exe $linkRoot"253118&clcid="$LHex dlPreReq $fr MSI45 Windows6.0-KB942288-v2-x86.msu $linkRoot"139108&clcid=0x409" dlPreReq $fr MSI45 Windows6.0-KB942288-v2-x64.msu $linkRoot"139110&clcid=0x409" dlPreReq $fr VCRedist vcredist_x86.exe $linkRoot"195255&clcid="$LHex dlPreReq $fr VCRedist vcredist_x64.exe $linkRoot"195257&clcid="$LHex dlPreReq $fr VCRedist9SP1 vcredist_x86.exe $linkRoot"299417&clcid="$LHex dlPreReq $fr VCRedist9SP1 vcredist_x64.exe $linkRoot"299585&clcid="$LHex dlPreReq $fr IDCRL wllogin_32.msi $linkRoot"194721&clcid="$LHex dlPreReq $fr IDCRL wllogin_64.msi $linkRoot"194722&clcid="$LHex dlPreReq $fr Msoidcrl msoidcli_32bit.msi $linkRoot"317650&clcid="$LHex dlPreReq $fr Msoidcrl msoidcli_64bit.msi $linkRoot"317651&clcid="$LHex } else { write-host "No folder selected, operation was aborted. Run Create-CRM2013Redist to retry." } } #kick off the script Create-CRM2013Redist #End Script Источник: http://blogs.msdn.com/b/crminthefiel...onnection.aspx
Опции просмотра | |
