Старый 28.10.2006, 16:40   #1
25,626 / 848 (80) +++++++
Fred Shen: Undefined nodes in System Documentation after applying KR1
Источник: http://fredshen.spaces.live.com/Blog...E4E3!180.entry
I found that if using en-gb or de-at language after applying Kernel Roll Up 1, it will end up with Undefined nodes in System documentation. At the same time, on the property sheet of AOT, you may also find some object property displayed as *undefined* as well.
What you need to do is edit your ktd file, like axsysen-gb.ktd, and locate line 1393, remove the blank line between Apostrophe(') and 1245. Everything should be back to normal.
That is because ktd file contains the help text for kernel-defined method and property. The blank line makes AX unable to translate the relevant help texts.
Fred Shen: New server-based batch framework in AX2009 Blog bot DAX Blogs 0 04.09.2008 07:06
Fred Shen: Consuming a Web Service in Dynamics AX 4 Blog bot DAX Blogs 0 28.10.2006 16:40
Fred Shen: Limited sessions in Axapta Blog bot DAX Blogs 0 28.10.2006 16:40
Fred Shen: Development Features of Dynamics Ax (Axapta) 4.0 Blog bot DAX Blogs 0 28.10.2006 16:40
Пропал help из System Documentation LedgerVoucher DAX: Программирование 3 08.07.2002 17:39
Часовой пояс GMT +3, время: 04:18.
