Старый 12.04.2007, 11:50   #1
25,643 / 848 (80) +++++++
DynamicsTech: How to Setup Alerts in Dynamics Ax 4.0
Источник: http://dynamicstech.blogspot.com/200...ics-ax-40.html
INTRODUCTION
This article describes how to set up Business Alerts in Microsoft Dynamics AX 4.0. This article also describes how to set the e-mail address from which Business Alert e-mail messages are sent.
MORE INFORMATION
Configure a user account to receive alerts
To configure a user account to receive alerts, follow these steps:
1. In the Navigation Pane, click Administration, and then click Users.
2. Select a user, and then click User Options.
3. Verify that the e-mail address where you want the user to receive alerts is in the E-mail field.
4. In the Receive alerts every (minutes) box, type 1.
5. In the Pop-up link destination list, click To alert.
6. In the Send alert as e-mail message list, click Define on each alert rule.
7. In the Show pop-ups list, click Define on each alert rule, and then click Apply.
8. Close the Options window.
Add the "E-mail distributor batch" job
The "E-mail distributor batch" job is the batch job that monitors and sends e-mail messages. To add the "E-mail distributor" batch job, follow these steps:
1. In the Navigation Pane, click Administration, expand Periodic, expand E-mail processing, and then click Batch.
2. In the "E-mail distributor batch" window, click Recurrence.
3. In the Recurrence window, click No end date.
4. Click Minutes.
5. In the Count box, type 1, and then click OK.
6. In the "E-mail distributor batch" window, click to select the Batch processing check box, and then click OK.Note You receive an Infolog message that resembles the following message:
Information: The E-mail distributor batch job is added to the batch queue.
7. Click Close to close the Infolog dialog box.
8. On the Tools menu, click Development tools, and then click Application Hierarchy Tree.
9. Expand Forms, and then double-click Tutorial_EventProcessor.
10. On the Tutorial_EventProcessor form, click Start, and then verify that the status is In waiting.
Set up a new alert rule
Alert rules define when alerts are sent and how they are received. To set up a new alert rule, follow these steps:
1. In the Navigation Pane, click General ledger, and then click Chart of accounts.
2. On the Overview tab, right-click a cell in the Account name column, and then click Create alert rule.
3. In the Alert me when area, select the field that you want to monitor with this alert rule in the Field list. For example, select Account name.
4. In the Event list, select the event that you want to trigger an alert. For example, select has changed.
5. In the Alert me for area, select the All records in Ledger chart of accounts option.
6. In the Alert me until area, select the No end date option.
7. In the Alert who area, select the user account that you want to receive this alert in the User ID list.
8. In the Also alert me by area, click to select the Show pop-ups check box.
9. Click to select the Send e-mail check box, and then click OK.
10. Close the "Manage alert rules" window.
Test the alert
To test the alert that you have set up, follow these steps:
2. On the Overview tab, change the name of the account for which you set up a new alert.
3. In the Navigation Pane, click Administration, click Periodic, click E-mail processing, and then click E-mail sending status.
4. The "E-mail sending status" window shows e-mail alerts that have been sent.
Set the e-mail address from which alerts are sent
You can set the e-mail address from which alerts are sent by selecting an e-mail template. To do this, follow these steps:
1. In the Navigation Pane, click Basic, click Alerts, and then click Alert parameters.
2. In the E-mail ID list, select the e-mail template from which you want e-mail alerts to be sent.
DynamicsTech: How to modify the behavior of dialog boxes to enable forms to appear in full-screen mode in Microsoft Dynamics AX Blog bot DAX Blogs 0 13.04.2007 12:10
DynamicsTech: How to do the setup for Version Control System in Ax 4.0 Blog bot DAX Blogs 0 12.04.2007 11:50
Часовой пояс GMT +3, время: 10:44.
