Старый 25.03.2008, 16:05   #1
axStart: Programming against a DLL.
Источник: http://axstart.spaces.live.com/Blog/...C0A0!286.entry
We all have trouble to find the correct function in a DLL. There is simply no in telly morph available on that point. Let’s take this example: I was analysing the function key integration in some forms of AX. They use the axhotkey.DLL for that (class jmgFkeyHandler). From AX point of view you don’t know what kinds of other function are available in that DLL.
However there are some handy tools on the internet that can help you out:
Anywhere PE Viewer
http://www.ucware.com/apev/index.htm
The first screenshot shows the hotkey DLL used in AX 3.0 the next screenshot shows the DLL function in 4.0.
So now I know for sure that the 3.0 solution is not compatible with AX 4.0. Because the DLL funtions are not there anymore.
Старый 26.03.2008, 11:06   #2
gl00mie is offline
gl00mie
3,684 / 5803 (201) ++++++++++
Неуместный квантор общности
Старый 28.03.2008, 12:56   #3
kashperuk is offline
kashperuk
Аватар для kashperuk
4,361 / 2084 (78) +++++++++
Цитата из Тренинга по разработке:
One method used to view a list of functions in a DLL is the dumpbin.exe program. This is shipped with Microsoft® Visual Studio®. Use the following line in a command prompt to obtain a list of functions in Kernel32.dll
dumpbin /exports c:\windows\system32\kernel32.dll
Проблема с самописной DLL. VAlek DAX: Программирование 18 28.12.2008 10:37
axStart: Making singleton objects from classes, DLL and CLR’s in AX. Blog bot DAX Blogs 2 04.01.2008 00:48
Client Axapta 3.0 SP4 и Linux. Как запустить? Daiver DAX: Администрирование 10 28.06.2007 15:59
Axapta Lessons: Axapta DLLs Blog bot DAX Blogs 0 28.10.2006 18:22
при вызове функции из своей DLL, вылетает ошибка Delfins DAX: Программирование 9 07.03.2006 19:29
Часовой пояс GMT +3, время: 19:40.
