Старый 08.05.2008, 03:18   #1
25,643 / 848 (80) +++++++
Dynamics AX: DAXGuy: Infopath, Web Services & AX Integration
Источник: http://dynamics-ax.blogspot.com/2008...rvices-ax.html
Well DAXGuy over at daxguy.blogspot.com wrote a post recently that really showed how to take infopath and make use of it in an integrated with Web Services solution for Dynamics AX.
The link to that post can be found here: Direct Link
He really did a good job, and gives the entire example project up for download. I recommend you check it out, to really get a feeling for the flow of how such things can work, right now in the current release of Dynamics AX 4.0, plus DAX 2009.
I wrote about similar topics myself, and a list of them follows:
Thanks DAXGuy for that great post. And check back soon here, as I have some great new posts coming soon!Find a job at: DynamicsAXJobs.com, also post a job for only $99.00!
Arijit Basu: Infopath, Web Services & AX Integration Blog bot DAX Blogs 0 04.05.2008 23:05
Consuming External Web Services (Dynamics AX 4) Blog bot DAX Blogs 0 19.02.2008 06:41
Inside Dynamics AX 4.0: The Web Framework Blog bot DAX Blogs 0 25.10.2007 03:04
Часовой пояс GMT +3, время: 16:07.
