Старый 16.10.2008, 00:05   #1
25,626 / 848 (80) +++++++
Solutions Monkey: Disabling Bound Fields through code
Источник: http://blogs.msdn.com/solutions/arch...ough-code.aspx
You can make a bound field as read only or hide the Lookupbutton of the bound field through code in the page load event.
For example
AxBoundField boundField = AxGridView1.Columns[i] as AxBoundField;
boundField.ReadOnly = true;
or
boundField.LookupButtonDisplaySettings = LookupButtonDisplaySettings.Never;
If they do want to hide the lookup for specific rows, then they should use a template field instead of the AxBoundField. For example ,
In the below code DataSet Name is DemoSet, Table Name is Table1 and FieldName is AccountNum
asp:TemplateField ConvertEmptyStringToNull="False"
HeaderText="" SortExpression="AccountNum">
Code Behind to hide the lookup control conditionally and disable the cell
protected void AxGridView1_RowDataBound(object sender, GridViewRowEventArgs e)
if (e.Row != null && e.Row.RowType == DataControlRowType.DataRow)
/* disable the thrid column which displays accountnum and hide the lookup if the second field value is 1
DataSetViewRow dataRow = (DataSetViewRow)e.Row.DataItem;
bool isInternalProject = dataRow.GetFieldValue("Field2").ToString() == "1";
if (isInternalProject)
Control c = e.Row.Cells[2].FindControl("AxLookup1");
if ( c!= null)
c.Visible = false;
e.Row.Cells[2].Enabled = false;
Solutions Monkey: EP Page Life Cycle Blog bot DAX Blogs 0 18.02.2009 08:05
Solutions Monkey: Aggregation in EP Datasets Blog bot DAX Blogs 0 07.10.2008 06:05
Solutions Monkey: Role Center Security Blog bot DAX Blogs 0 28.05.2008 16:05
Solutions Monkey: EP 4.0 Questions Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 03:22.
