Старый 01.04.2009, 07:55   #21
vital.mih is offline
vital.mih
Код:
var invite4 =  GetAttributeValueFromID('new_date_protocol', crmForm.all.new_protocolsfordate.DataValue[0].id, 'new_invite4');
crmForm.all.new_invite.DataValue=invite4
function GetAttributeValueFromID(sEntityName, GUID, sAttributeName)
var authenticationHeader = GenerateAuthenticationHeader();
// Prepare the SOAP message.
var xml = "";
xml = xml+"<?xml version='1.0' encoding='utf-8'?>"+
"<soap:Envelope xmlns:soap='http://schemas.xmlsoap.org/soap/envelope/'"+
" xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'"+
" xmlns:xsd='http://www.w3.org/2001/XMLSchema'>"+
authenticationHeader+
"<soap:Body>"+
"<Retrieve xmlns='http://schemas.microsoft.com/crm/2007/WebServices'>"+
"<entityName>"+sEntityName+"</entityName>"+
"<id>"+GUID+"</id>"+
"<columnSet xmlns:q1='http://schemas.microsoft.com/crm/2006/Query' xsi:type='q1:ColumnSet'>"+
"<q1:Attributes>"+
"<q1:Attribute>"+sAttributeName+"</q1:Attribute>"+
"</q1:Attributes>"+
"</columnSet>"+
"</Retrieve>"+
"</soap:Body>"+
"</soap:Envelope>";
// Prepare the xmlHttpObject and send the request.
var xHReq = new ActiveXObject("Msxml2.XMLHTTP");
xHReq.Open("POST", "/mscrmservices/2007/CrmService.asmx", false);
xHReq.setRequestHeader("SOAPAction","http://schemas.microsoft.com/crm/2007/WebServices/Retrieve");
xHReq.setRequestHeader("Content-Type", "text/xml; charset=utf-8");
xHReq.setRequestHeader("Content-Length", xml.length);
xHReq.send(xml);
// Capture the result.
var resultXml = xHReq.responseXML;
// Check for errors.
var errorCount = resultXml.selectNodes('//error').length;
var result = resultXml.selectSingleNode("//q1:" + sAttributeName).nodeTypedValue;
if (errorCount != 0)
 var msg = resultXml.selectSingleNode('//description').nodeTypedValue;
result = " ";
// Display the retrieved value.
else
alert('test')
return result;
Сначала показывает test, а затем нижеописанное сообщение
Последний раз редактировалось vital.mih; 01.04.2009 в 07:59.
Старый 02.04.2009, 07:28   #22
vital.mih
ну что нет ни у кого идей??
Старый 02.04.2009, 12:05   #23
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
3,243 / 896 (36) +++++++
Lightbulb
Сообщение от vital.mih Посмотреть сообщение
Это только идеи, которые не могу проверить на практике, потому что в отпуске с ноутом на коленях .
Итак:
1. Стоит всё-таки везде где надо ставить ; В вашем случае это строка 3 - crmForm.all.new_invite.DataValue=invite4;
2. Перед присвоением - поставьте alert(invite4); и убедитесь, что возвращается корректное значение.
3. Убедитесь, что поле new_invite вынесено на форму и желательно таки указать его тип, чтобы знать с чем имеем дело.
4. Перед выполнением поиска желательно вставить проверку, что crmForm.all.new_protocolsfordate.DataValue != null &&crmForm.all.new_protocolsfordate.DataValue.length != 0
Пробуйте. Если опять не заработает - есди дождётесь меня из отпуска и Вам не помогут - постараюсь помочь.
Старый 02.04.2009, 12:27   #24
Bondonello is offline
Bondonello
Kostya Afendikov
Аватар для Bondonello
510 / 106 (5) +++++
Да, пользуйтесь alert`ами, эту функцию привел как пример на основе sdk
сейчас заканчиваю проект у себя, так что пока нет свободного времени. На след неделе просмотрю и переделаю функцию. Так что сейчас дебажте сами
Старый 02.04.2009, 15:15   #25
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
Lightbulb
Сообщение от Bondonello Посмотреть сообщение
А ещё лучше - волшебной коммандой debugger; (при этом не забудьте включить отладку скриптов у себя в браузере).
Старый 06.04.2009, 15:04   #26
vital.mih
не проходит короче эта строчка:
Как бы задать условие, чтобы она не выполнялась, если искомый атрибут null?
Старый 06.04.2009, 15:07   #27
vital.mih
или как задать, чтобы в строке
errorCount становилось единицей в случае, если искомый атрибут null?
Старый 06.04.2009, 16:35   #28
vital.mih
А как вытащить значение атрибута с типом дата?
Старый 06.04.2009, 17:07   #29
Bondonello
Kostya Afendikov
510 / 106 (5) +++++
Точно так же, только потом его необходимо преобразовать в необходимый для себя
вот вариант "по-быстрому"
var datec;
datec = GetAttributeValueFromID("new_entity","{63802E36-49AB-DC11-94ED-000423AF733E}","new_daterate");
var year;
var month;
var day;
year = datec.substr(0,4);
month = datec.substr(5,2);
day = datec.substr(8,2);
crmForm.all.new_mydaterate.DataValue =new Date(year,month,day);
Старый 06.04.2009, 17:16   #30
vital.mih
var datec;
var year;
var month;
var day;
все здорово, но у меня почему то дата на месяц больше. Хотя alert(month) показывает корректно...
Старый 06.04.2009, 17:51   #31
SilentBlaze is offline
SilentBlaze
А как присвоить Lookup-атрибут одной сущности Lookup аттрибуту другой сущности? Т.е. допустим у аккаунта есть связь c TestEntity (N:1) и у контакта есть связь с TestEntity (N:1). Как на форме создания (обновления) контакта при выборе Parent account подставить автоматически связь TestEntity аккаунта?
На OnChanged событии аттрибута parent_account я уже получил GUID TestEntity выбранного аккаунта. Осталось только присвоить crmForm.all.testentityid.DataValue значение. Но DataValue в этом случае NULL (пользователь ничего не выбрал). Кто-нибудь сталкивался с такой задачей? Есть идеи? Спасибо.
Старый 06.04.2009, 18:58   #32
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
Lightbulb
Месяцы нумеруются от 0 до 11. Об этом тут
Поэтому используйте примерно такой код:
Код:
var datec;
var year;
var month;
var day;
month = datec.substr(5,2) - 1;
Старый 06.04.2009, 19:04   #33
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
Lightbulb
Сообщение от SilentBlaze Посмотреть сообщение
Тема заполнения лукапов уже не раз поднималась на форуме. Воспользовались бы поисковиком или SDK и нашли бы. Например такое
Старый 14.04.2009, 09:48   #34
vital.mih
А каким образом,наоборот, присвоить атрибут из "подвязанной сущности" атрибуту "главной", ведь там нет лукапа.
Старый 14.04.2009, 14:19   #35
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
Lightbulb
1. Из подвязанной сущности, как не крутись, а айдишик родительской - вытащить можно. Если не нет на форме, то воспользовавшись веб сервисами.
2. Выполнить апдейт полей родительской сущности по полученному айдишнику родительской записи средствами веб сервисов.
Последний раз редактировалось a33ik; 14.04.2009 в 15:14.
Старый 07.07.2009, 08:39   #36
vital.mih
Кстати, так вопрос и не решился, если искомый атрибут null?
Старый 07.07.2009, 09:45   #37
Dekan is offline
Dekan
Аватар для Dekan
171 / 11 (1) +
Я вопрос с null решил так:
telephone1= resultXml.selectSingleNode("//q1:telephone1");
if ( telephone1 !=null )
crmForm.all.telephone1.DataValue = telephone1.nodeTypedValue
else {crmForm.all.telephone1.DataValue = null}
работает.
Старый 08.09.2010, 05:49   #38
Dicora is offline
Dicora
Молодцы =))
А с Гуидами в Пиклистке.... жжете.. ржал минуты 2 рассмешили =))))
Спасибо!
Старый 08.09.2010, 10:53   #39
a33ik is offline
a33ik
Чайный пьяница
Аватар для a33ik
Сообщение от Dicora Посмотреть сообщение
Молодцы =))
Спасибо!
Не совсем понял, почему посмешило. Можете объяснить?
Как получить значение поля одной сущности при обработке формы другой сущности zhenek Dynamics CRM: Разработка 25 05.07.2011 16:19
Получение атрибута из другого объекта Казарин Александр Dynamics CRM: Разработка 6 20.10.2008 18:08
Создание объекта сущности из другого объекта! SnSS Dynamics CRM: Разработка 5 29.05.2008 13:38
Отнимание одного значения от другое pkost Dynamics CRM: Разработка 2 14.03.2008 07:48
Rollup 2 и обкрытие атрибута сущности для кастомизации AHAPX1CT Dynamics CRM: Администрирование 1 23.08.2007 13:45
Часовой пояс GMT +3, время: 01:08.
