Старый 22.05.2009, 14:05   #1
axcoder: Search for C#
Источник: http://axcoder.blogspot.com/2009/05/search-for-c.html
It is obvious for somebody, but it can help somebody novice.
Since version 4 Dyanmics Ax requires .NET framework installation, so you can rely on the fact that .NET FW exists. There is also constantly improving intargetion of .NET in X++, so you can use .NET framework as a huga library of various utilities. For example, Ax uses System.Text.RegularExpression for checking e-mail format.
So sometimes, you can search the internet for code snippet, performing some task, you need, but if you type "http .net" you can get lots of irrelevant results since .net is an often part of web page address. Type "http C#" instead and you probably get what you want.
Microsoft Dynamics CRM Team Blog: CRM Accelerators – Part IV – Enterprise Search Accelerator Blog bot Dynamics CRM: Blogs 0 26.08.2008 23:05
Dianne Siebold: Limit MSDN Search to AX Content Only (4.0) Blog bot DAX Blogs 0 16.02.2008 04:41
Inside Dynamics AX 4.0: Common Search Blog bot DAX Blogs 0 29.10.2007 10:50
Arijit Basu: Search Windows Live from AX Blog bot DAX Blogs 0 02.06.2007 17:13
axaptafreak: AOT search within search results Blog bot DAX Blogs 0 16.11.2006 17:40
Часовой пояс GMT +3, время: 15:29.
