Старый 18.07.2009, 09:10   #1
mscrm4ever: CRM 4.0 Setting a Picklist Default Value
Источник: http://mscrm4ever.blogspot.com/2009/...ult-value.html
Currently Dynamics supports setting default values for two attribute types: PicklistAttributeMetaddata (Picklist) and BooleanAttributeMetadata (bit fields). If you intend to set the default using custom code you need to follow the below process:
1. Retrieve the attribute metadata (unless you’re creating a new one) using RetrieveAttributeRequest
2. Cast the returned AttributeMetadata to a PicklistAttributeMetadata.
3. Set the picklist metadata Default value to an integer of you choice.
4. Update the attribute metadata using UpdateAttribute Request.
5. Publish the changes using PublishXml Request.
The bellow code is a working example which sets the account Relationship Type (customertypecode) picklist to Customer (value = 3).
using System;
using System.Collections.Generic;
using System.Text;
using Microsoft.Crm.Sdk;
using Microsoft.Crm.SdkTypeProxy;
using Microsoft.Crm.Sdk.Metadata;
using Microsoft.Crm.SdkTypeProxy.Metadata;
namespace GI.Sendbox
class Program
static void Main(string[] args)
try
/* Create Authenticatio Token */
CrmAuthenticationToken token = new CrmAuthenticationToken();
token.AuthenticationType = 0;
token.OrganizationName = "MicrosoftCRM";
/* Create a CrmService end point */
CrmService crmService = new CrmService();
crmService.UnsafeAuthenticatedConnectionSharing = true;
crmService.Url = "http://localhost:5555/mscrmservices/2007/crmservice.asmx";
crmService.UseDefaultCredentials = true;
crmService.CrmAuthenticationTokenValue = token;
/* Create a MetadataService end point */
MetadataService metaService = new MetadataService();
metaService.Url = "http://localhost:5555/mscrmservices/2007/metadataservice.asmx";
metaService.UseDefaultCredentials = true;
metaService.UnsafeAuthenticatedConnectionSharing = true;
metaService.CrmAuthenticationTokenValue = token;
/* Retrieve the attribute metadata */
RetrieveAttributeRequest attributeRequest = new RetrieveAttributeRequest();
attributeRequest.EntityLogicalName = "account";
attributeRequest.LogicalName = "customertypecode"; //Relationship Type picklist
RetrieveAttributeResponse attributeResponse =
(RetrieveAttributeResponse)metaService.Execute(attributeRequest);
/* Cast the attribute metadata to a picklist metadata */
PicklistAttributeMetadata picklist =
(PicklistAttributeMetadata)attributeResponse.AttributeMetadata;
/* set the default value to "customer" (3) */
picklist.DefaultValue = (object)3;
/* update the attribute metadata */
UpdateAttributeRequest updateRequest = new UpdateAttributeRequest();
updateRequest.Attribute = picklist;
updateRequest.EntityName = "account";
updateRequest.MergeLabels = false;
metaService.Execute(updateRequest);
/* Publish the changes */
PublishXmlRequest request = new PublishXmlRequest();
request.ParameterXml = @"
account
PublishXmlResponse response =
(PublishXmlResponse)crmService.Execute(request);
catch(System.Web.Services.Protocols.SoapException sex)
Console.WriteLine(sex.Detail.OuterXml);
catch(Exception ex)
Console.WriteLine(ex.ToString());
Старый 20.07.2009, 09:44   #2
Артем Enot Грунин is offline
Артем Enot Грунин
Аватар для Артем Enot Грунин
3,912 / 623 (28) +++++++
Записей в блоге: 151
Ума не приложу, на кой черт это может понадобиться.
Microsoft Dynamics CRM Team Blog: Building a Self-Contained Virtual CRM Development Server Blog bot Dynamics CRM: Blogs 0 05.05.2009 10:05
Microsoft Dynamics CRM Team Blog: CRM 4.0: Checkbox style Multi-Select Picklist Blog bot Dynamics CRM: Blogs 0 01.04.2009 05:07
mscrm4ever: CRM 4.0 Supported Multi Select (Picklist) Control Blog bot Dynamics CRM: Blogs 0 25.12.2008 15:05
Часовой пояс GMT +3, время: 08:46.
