Старый 07.09.2010, 19:06   #1
gustafwesterlund: IFD on Windows Server 2008 R2 problem with plugin registration
Источник: http://gustafwesterlund.blogspot.com...2-problem.html
A customers system I was working on today has just been reconfigured to and IFD setup. The server is a Windows Server 2008 R2 and I had made sure that it worked on port 80 with NTLM/AD internally. However, when I tried to connect the plugin registration wizard in the normal manner, it just gave me an error:
"Request IP Address has different address family from network address."
I found and interesting thread on Egghead café where some guys had run in to the same problem.
http://www.eggheadcafe.com/software/...d-problem.aspx
So I did as they suggested, added the servername to the hosts-file to the IP 127.0.0.1. If you don't know what this means, it works as a local DNS. The IP 127.0.0.1 is assigned to always be the local computer and "localhost" is usually directed to this adress. You can try by browsing to it if you havn't tried.
The hosts file can be found in C:\Windows\System32\Drivers\etc\hosts. There are usually an entry or two in there so you can usually figure it out, the syntax is simple:
127.0.0.1 servername
If you tried pinging the servername before doing this, you would get the IP v6 address, after doing this, you will get an answer from 127.0.0.1 and after confirming this, you should have no problems getting it up and running.
Gustaf Westerlund
CEO, Chief Architect and co-Founder at CRM-konsulterna AB
www.crmkonsulterna.se
emeadaxsupport: Unable to edit the DCOM settings for IIS WAMREG admin service on a Windows Server 2008 R2 when trying to configure Kerberos Authentication for Role Centers Blog bot DAX Blogs 0 27.01.2010 02:08
emeadaxsupport: AX 2009 Setup fails to install IIS Components on Windows Server 2008 R2 Blog bot DAX Blogs 0 12.01.2010 04:44
emeadaxsupport: Unable to validate the AX 2009 Workflow Webservice URL on a Windows Server 2008 R2 x64 Blog bot DAX Blogs 0 05.01.2010 19:16
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 4.0 and AX 2009 are compatible with Microsoft Windows 7 and Microsoft Windows Server 2008 R2 Blog bot DAX Blogs 0 22.09.2009 04:06
jodonnell: Microsoft Dynamics CRM 4.0 on Windows 7 & Windows Server 2008 R2 Blog bot Dynamics CRM: Blogs 0 21.09.2009 22:05
Часовой пояс GMT +3, время: 08:33.
