Старый 09.12.2010, 22:11   #1
Dynamics AX Sustained Engineering: Truncation of data on the Project Timesheet Lines Comment Field
Источник: http://blogs.technet.com/b/dynamicsa...ent-field.aspx
Scenario:
Customers experiencing truncation of the comment field on the lines of the Project Timesheet.
Resolution:
may consider making the following changes to their system to help resolve the issue.
  1. Change EDT TransTxt to be at least stringsize of 255.
  2. For ProjJournalTrans Table change the EDT for field Txt from TSComment to TransTxt.
Note: It is important to perform step 1 before step 2 to ensure no data is lost in the EDT conversion from TSComment to TransTxt. We highly recommened these changes are tested in a test environment before deploying in production.
Dynamics AX Sustained Engineering: Fill Utility incorrectly updating a field in a form datasource Blog bot DAX Blogs 1 27.05.2010 23:05
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 4.0 and AX 2009 are compatible with Microsoft Windows 7 and Microsoft Windows Server 2008 R2 Blog bot DAX Blogs 0 22.09.2009 04:06
Часовой пояс GMT +3, время: 13:12.
