Старый 09.03.2011, 02:21   #1
Dynamics AX Sustained Engineering: Fiscal Reference Inquiry allows editing of Text ID field after posting of invoice
Источник: http://blogs.technet.com/b/dynamicsa...f-invoice.aspx
Problem:
Text ID field on the Fiscal Reference form allows edit after Invoice has been posted.
Resolution:
To resolve the issue the following change can be made which will not allow edit of the Text ID field.
1. Open the AOT
2. Expand Forms
3. Locate and expand TmpFiscalReference_BR
4. Expand Data Sources
5. Expand TmpFiscalReference_BR
6. Expand Fields
7. Locate LegalTextID
8. Right-click on LegalTextID and choose Properties
9. Locate the AllowEdit property and set the Value = No
10. Save the changes to the form.
Dynamics AX Sustained Engineering: POS Transaction with Sales Order that nets to $0.00 posting failure in statement Blog bot DAX Blogs 0 06.01.2011 20:16
Dynamics AX Sustained Engineering: How to prevent transaction reversal from posting to closed dimensions Blog bot DAX Blogs 0 22.04.2010 23:05
Часовой пояс GMT +3, время: 08:49.
