Старый 03.08.2011, 09:11   #1
emeadaxsupport: Enterprise Portal Dlls rules for applying hotfixes or moving environments
Источник: http://blogs.msdn.com/b/emeadaxsuppo...ironments.aspx
There are a few Enterprise Portal dlls that can be unusual with regards to applying hotfixes - when deploying kernel hotfixes they'll be automatically updated, but there are some application fixes which include a new webParts.cab, and then some of the dlls may need to be manually deployed/installed. The dlls in question are:
  • Microsoft.Dynamics.Framework.portal.dll
  • Microsoft.Dynamics.Compliance.InternalControlsManager.dll
  • Microsoft.Dynamics.WebParts.dll
  • Microsoft.Dynamics.Framework.Portal.CommonControls.dll
Our colleagues in the US have written a great post which explain the full details on exactly what to check in which places so that you can get everything correctly up to date:
http://blogs.msdn.com/b/axsupport/ar...l-ep-dlls.aspx
emeadaxsupport: Unable to deploy AX 2009 Enterprise Portal on SharePoint 2010 even after patching setup files with hotfix 2278963 Blog bot DAX Blogs 0 08.12.2010 03:14
emeadaxsupport: Resolving some issues you may experience when creating an AX 2009 Role Center and Enterprise Portal Site using SharePoint Server/Foundation 2010 after installing Microsoft Dynamics AX 2009 SP1 hotfix 2278963 Blog bot DAX Blogs 1 24.09.2010 11:34
emeadaxsupport: HTTP 401 Error when trying to deploy/create an Enterprise Portal site on a load balanced farm using a hardware load balancer Blog bot DAX Blogs 0 06.05.2010 03:16
emeadaxsupport: How to manually deploy ODC Files to Microsoft Dynamics AX 2009 Enterprise Portal Blog bot DAX Blogs 0 17.02.2010 21:07
emeadaxsupport: AxUpdatePortal.exe does not update Enterprise Portal when not running from an elevated command prompt Blog bot DAX Blogs 0 26.07.2009 15:07
Часовой пояс GMT +3, время: 18:45.
