Старый 03.08.2011, 09:11   #1
Microsoft Dynamics CRM Team Blog: Announcing Microsoft Dynamics CRM SDK Update v5.0.5
Источник: http://blogs.msdn.com/b/crm/archive/...te-v5-0-5.aspx
Microsoft Dynamics CRM SDK Version 5.0.5 is now live on MSDN downloads and in the MSDN library!There are some exciting additions in this release, including the
following:
  • Updated assemblies to match Update Rollup 3. For Microsoft Dynamics CRM Online, updates are installed for you. For other deployment types, you can get Update Rollups from the Microsoft Download Center or from Microsoft Update.
  • The Beta release of the Developers Toolkit for CRM 2011 and Online is now included in the SDK! This will be fully incorporated in an upcoming release.
  • Added a new tool for analyzing plug-in performance, called the Plugin Profiler.
  • Added more Visual Basic .NET versions of the sample code.
  • Added support for saving and re-using server configurations in the ServerConnection helper code, making it easier to run the sample code repeatedly with minimal prompts.
  • Added a new extension to the CrmSvcUtil to generate a helper file that includes enumerations for all option sets. This will make it much easier to set and test values for option sets in your code. We’ll be updating sample code to use these enumerations in an upcoming release, but there is enough information here to get you started.
  • Added new sample code:
    • Sample: Associate and Disassociate Records Using the REST Endpoint with JScript
    • Sample: Associate and Disassociate Records Using the REST Endpoint with Silverlight
    • Sample: Distribute Campaign Activities to Dynamic and Static Lists
    • Sample: Work with Activity Party Records
  • See more updates in the Release History on the first page.
The next SDK update is scheduled for the end of August. Feel free to send Feedback.
Thanks for all the hard work by the SDK team!
Amy Langlois
Старый 03.08.2011, 09:11   #2
dynamics-community.at: CRM SDK Version 5.0.4 ab sofort auf MSDN
Источник: http://feedproxy.google.com/~r/dynam...ahWQ/post.aspx
Das Microsoft Dynamics CRM SDK Version 5.0.4. ist ab sofort auf MSDN downloadsund MSDN libraryverfügbar. Dieses neue SDK release beinhaltet unter anderem:
- Upgedated Assemblies für Update Rollup 3. (Für Microsoft Dynamics CRM Online Kunden wurde dieses Rollup bereits installiert – für andere Deployments finden Sie die Rollups im  Microsoft Download Centeroder über Microsoft Update.
- Das Beta Release des Developer Toolkits für CRM 2011 und Online ist jetzt im SDK inkludiert.
- Neues Took für die Analyse der Plug-in Performance (“Plugin Profiler”)
- Mehr Visual Basic .NET Versionen bei Beispiel Codes
- Support für das Speichern und weiterverwenden von Server Konfigurationen im ServerConnection helper code um das wiederholte Laufenlassen von Beispielcodes mit minimalen Prompts zu ermöglichen.
- neuer Beispiel Code  zb für :
     o Sample: Associate and Disassociate Records Using the REST Endpoint with JScript
     o Sample: Associate and Disassociate Records Using the REST Endpoint with Silverlight
     o Sample: Distribute Campaign Activities to Dynamic and Static Lists
     o Sample: Work with Activity Party Records
Microsoft Dynamics CRM Team Blog: Update Rollup 17 for Microsoft Dynamics CRM 4.0 Blog bot Dynamics CRM: Blogs 0 09.05.2011 21:12
Microsoft Dynamics CRM Team Blog: Announcing the Customer and Partner Relationship Management Portals! Blog bot Dynamics CRM: Blogs 0 09.03.2011 02:21
Microsoft Dynamics CRM Team Blog: Troubleshooting the Microsoft Dynamics CRM Client for Outlook Blog bot Dynamics CRM: Blogs 0 30.05.2009 12:05
Microsoft Dynamics CRM Team Blog: Update Rollup 2 for Microsoft Dynamics CRM 4.0 Blog bot Dynamics CRM: Blogs 0 20.01.2009 21:05
Microsoft Dynamics CRM Team Blog: Troubleshooting the Microsoft Dynamics CRM E-mail Router Blog bot Dynamics CRM: Blogs 0 09.01.2009 06:03
Часовой пояс GMT +3, время: 14:29.
