Старый 26.08.2011, 21:13   #1
25,644 / 848 (80) +++++++
emeadaxsupport: Retail: How to access multiple POS from one machine
Источник: http://blogs.msdn.com/b/emeadaxsuppo...e-machine.aspx
Topic:
The description in the POS Technical Reference.pdf describes how to adjust the configuration file (original text further down on the page).
In addition to the original description, I want to provide the example file and what you will see at the POS when you start it.
Example File POS.EXE.CONFIG
Result:
It is now possible to connect to a different configuration / POS database
Controlling startup
Starting
Microsoft Dynamics AX for Retail POS can be controlled by the config file and
startup parameters.
The config file
The
config file is an XML file whose file name is POS.exe.config. It is located in
the same directory as the EXE file. The config file is constructed as follows:
As
shown above, the config file can have one or more sections specified within the
configSection tag. Each section must have its own tag and can have the
following parameters:
LocalConnectionString
Tells
Retail POS about the connection string. A typical connection string is shown in
the example config file above.
LocalUserName
Stores
an encrypted user name that connects to the database if integrated security is
set to false in the connection string. An unencrypted name can also be put
directly into LocalConnectionString.
LocalPassword
Stores
an encrypted password for the person who connects to the database; if
integrated, security is set to false in the connection string. An unencrypted
password can also be put directly into LocalConnectionString.
RemoteConnectionString,
RemoteUserName, and RemotePassword
Not
used by Retail POS. Retail POS Technical Reference Controlling startup 2
StoreId
The ID of the store. Because a number of settings are
store-related, changing the store ID can result in an error if related store
data is missing.
TerminalId
The ID of the POS register. When Retail POS starts, the
terminalID of the config file must match an entry found in the
RBOTerminalTable. Otherwise, an error occurs.
DataAreaId
This parameter equals the field DATAAREAID found in most of
the tables in the database. This field makes it possible to start Retail POS
with different data, depending on the dataareaid.
DatabasePhysicalFilePath
When Retail POS starts and no database is found, a database
is created. If you must create the database using a path other than the default
path, you can specify it in the parameter DatabasePhysicalFilePath.
UseLocalSqlExpress
If this is set to true, Retail POS does not install
Microsoft SQL Server Express.
Author: Kim
Reviewer: Kim
Date 26. August
emeadaxsupport: Store Connect: error “Multiple-step operation generated errors” Blog bot DAX Blogs 0 18.08.2011 18:11
furnemont: How-to series: Send SMS messages from CRM 2011 (part 3) Blog bot Dynamics CRM: Blogs 0 13.06.2011 12:11
emeadaxsupport: How to delete orphaned data remained from deleted company? Blog bot DAX Blogs 0 09.12.2010 16:11
emeadaxsupport: Possibilities to create Memory Dumps from crashing processes Blog bot DAX Blogs 0 12.05.2010 19:05
emeadaxsupport: How to open an AX form from your own help Blog bot DAX Blogs 0 26.07.2009 15:07
Часовой пояс GMT +3, время: 16:04.
