Старый 05.02.2013, 20:11   #1
25,644 / 848 (80) +++++++
bojensen: Dynamics: Import Data into AX from excel file
Источник: http://blogs.bojensen.eu/?p=4667
static void DataImportToAXFromExcel(Args _args)
    SysExcelApplication xlsApplication;
    SysExcelWorkBooks   xlsWorkBookCollection;
    SysExcelWorkBook    xlsWorkBook;
    SysExcelWorksheets  xlsWorkSheetCollection;
    SysExcelWorksheet   xlsWorkSheet;
    SysExcelRange       xlsRange;
    SysExcelCells       Cells;
    SysExcelCell        RCell;
    CommaIO             inFile;
    int                 nRow,i;
    DialogField         dialogPath;
    Dialog              dialog;
    Filename            filename;
    CustTable           custTable;
    CustAccount         custAccount;
    CustGroupId         custGroupId;
    CurrencyCode        currencyCode;
    dialog = new Dialog();
    dialogPath = dialog.addField(typeid(Filenameopen), File );
    dialog.run();
    if (dialog.run())
        filename = (dialogPath.value());
    inFile = new CommaIO (filename, );
    if (!inFile || infile.status() != IO_Status::Ok )
        throw error (strfmt(@,filename));
    try
        xlsApplication          = SysExcelApplication::construct();
        xlsWorkBookCollection   = xlsApplication.workbooks();
        xlsWorkBookCollection.open(filename);
        xlsWorkSheetCollection  = xlsApplication.worksheets();
        xlsWorkSheet            = xlsWorkSheetCollection.itemFromNum(1);
        Cells                   = xlsWorkSheet.Cells();
        nRow = 2;
        RCell = Cells.Item(nRow, 1);
        while(RCell.value().bStr() != )
            custAccount     = RCell.value().bStr();
            RCell           = Cells.item(nRow,2);
            custGroupId     = RCell.value().bStr();
            RCell           = Cells.item(nRow,3);
            currencyCode    = RCell.value().bStr();
            if(!CustTable::exist(custAccount))
                if(CustGroup::exist(custGroupId) && Currency::exist(currencyCode))
                    custTable.initValue();
                    custTable.AccountNum    = custAccount;
                    custTable.CustGroup     = custGroupId;
                    custTable.Currency      = currencyCode;
                    custTable.insert();
            nRow++;
        xlsApplication.quit ();
        xlsApplication.finalize ();
        info(Imported );
    catch( Exception::Error)
        //Close Excel.
        ttsabort;
        info(Unable to process the excel import );
Последний раз редактировалось Poleax; 06.02.2013 в 10:42.
ax-erp: Creating SSRS-Reports in Dynamics AX 2012 – What’s no longer possible in AX-reports Blog bot DAX Blogs 0 18.07.2012 12:11
dynamics-ax: Microsoft Dynamics AX 2012 Excel Add-in Blog bot DAX Blogs 0 08.06.2011 08:12
Microsoft Dynamics CRM Team Blog: Creating Custom Sample Data for Microsoft Dynamics CRM 2011 Blog bot Dynamics CRM: Blogs 0 07.01.2011 03:15
hariprasadp: Import Excel file data in to dynamics AX through Dynamics AX Blog bot DAX Blogs 0 17.12.2009 20:05
Часовой пояс GMT +3, время: 15:11.
