Старый 27.01.2015, 18:11   #1
25,644 / 848 (80) +++++++
palleagermark: Create QR codes from AX
Источник: http://www.agermark.com/2015/01/crea...s-from-ax.html
It seems like the Brazilian authorities are very modern in their approach to how you report to and communicate with them. I have found several neat things in AX from the Brazil specific features.
This time I stumbled over an assembly called QRCode and I thought I should look into what that was used for. It turns out you can create QR codes from AX pretty easy. Here is an example:
static void JobCreateQRCode(Args _args)
    Image           image;
    container       imageContainer;
    str             url;
    EFDocQRCode_BR  qrCode;
    // The url to create the QR code. Could also for example be an e-mail address
    url = 'http://www.agermark.com';
    // Create an instance of the QR code class
    qrCode = new EFDocQRCode_BR();
    // Generate a QR code for the URL and save the result to a container
    imageContainer = qrCode.generateQRCode(url);
    // Use AX's good old Image class to load the image from the container
    // and save it as a file
    image = new Image();
    image.setData(imageContainer);
    image.saveImage("F:\QrCode.jpg", ImageSaveType::JPG);
You can now open the file and see the resulting QR code.
It links to www.agermark.com. Which leads me to the thing I really don't understand about QR codes. For security reasons we are always told not to click an URL that doesn't seem familiar. But scanning QR codes having absolute no idea about where they lead to is perfectly alright. Go figure.
Последний раз редактировалось mazzy; 04.02.2015 в 23:00.
emeadaxsupport: AX Performance Troubleshooting Checklist Part 1B [Application and AOS Configuration] Blog bot DAX Blogs 0 05.09.2014 21:11
sashanazarov: AX Content: Create your own PDF guides from TechNet content Blog bot DAX Blogs 0 09.05.2014 12:11
palleagermark: Moving labels from AX 2012 R2 to RTM via XPO's Blog bot DAX Blogs 0 20.09.2013 13:11
palleagermark: Create your own shortcuts in AX forms Blog bot DAX Blogs 0 07.04.2011 12:11
Часовой пояс GMT +3, время: 09:28.
