Старый 05.10.2018, 19:12   #1
daxrunbase: AOT property for kernel objects are readable via reflection
Источник: https://www.daxrunbase.com/2018/10/0...ts-reflection/
There was a question recently on the Dynamics Community forums about finding out which enumeration to use behind an int type. It turned out that the table, field and enum in question was part of the kernel. Those entries reside under the System documentation node of the AOT, and they do not provide much meaningful details. Reflection works on them...
The post AOT property for kernel objects are readable via reflection appeared first on DAXRunBase.
daxrunbase: Change AOT objects without AX client Blog bot DAX Blogs 0 11.09.2018 16:11
How to find in AOT all objects named like... Blog bot DAX Blogs 0 25.09.2014 01:24
emeadaxsupport: Identifying damaged Table objects in the AOT MetaData Blog bot DAX Blogs 0 16.03.2010 21:05
SysDictCoder: Changing properties of AOT objects in code Blog bot DAX Blogs 0 04.05.2009 20:05
To find objects in AOT with particular properties Blog bot DAX Blogs 1 26.04.2008 07:33
Часовой пояс GMT +3, время: 21:37.
