Старый 07.09.2019, 11:21   #1
crmtipoftheday: Tip #1303: Apps and Flows, buses and future access
Источник: https://crmtipoftheday.com/1303/apps...future-access/
You are writing canvas apps and Flows, but what happens if you get hit by a bus? How do you make sure that someone will be able to edit them in the future?
Option 1: add them to a solution. If you create your Flow or canvas app in a solution, Flows and canvas apps are stored in the Common Data service, and they will be findable from the solution as well as the default solution for your environment.
Option 2: if you can’t use a solution, create your App or Flow as a service account, and then share it with yourself as a co-owner. That way other administrators will be able to get to your app or flow if you aren’t there.
Cover photo by Ricardo Esquivel from Pexels.
crmtipoftheday: Tip #1140: Get ready for October 2018 release Blog bot Dynamics CRM: Blogs 0 24.07.2018 14:11
crmtipoftheday: Tip #1094: It is Time to Go with the Flow Blog bot Dynamics CRM: Blogs 0 27.03.2018 09:11
Часовой пояс GMT +3, время: 01:23.
