How to get back Import users button in D365FO
Источник: http://alexvoy.blogspot.com/2024/08/...button-in.html
============== You may start experiencing the following issue with button Import users. It happens because Microsoft changed their approach to devboxes settings: As of November 15, 2023, certificates in your Microsoft Entra tenant are no longer installed in new one-box development environments by default. You can find more detail on how to install a certificate in this article, but we can use a shortcut using D365fo.tools. Here are the steps: 1) Go to Azure portal and select app registration and create a new one (name the app to be the same as the environment name & leave settings at default) 2) The app registration needs to have the following: a) 2 reply URLs > https:// & https:///oauth b) add the following API permissions to the App registration: 3) On the VM for the environment, open PowerShell 4) Run the following commands: a) Install-Module D365fo.tools, and accept all the prompts b) New-D365EntraIntegration -ClientId (client-id is the app registration id that was created) 5) The above command will save a certificate, which then needs to be uploaded to the app registration that was created Источник: http://alexvoy.blogspot.com/2024/08/...button-in.html
