Старый 13.12.2011, 22:11   #1
25,626 / 848 (80) +++++++
Dates In An Extended Query Range
Источник: http://alexvoy.blogspot.com/2011/12/...ery-range.html
Let's say we need to range all the BOM versions that are active as of today. For this purpose we can use an extended range in the query.
QueryBuildRange qbr;
if(!_args.record())
return;
// there is an active caller!
switch (_args.record().TableId)
case tablenum(InventTable):
inventTable = element.args().record();
this.query().dataSourceTable(tablenum(InventTable)).addRange(fieldnum(InventTable, ItemId)).value(inventTable.ItemId);
qbr = this.query().dataSourceTable(tablenum(BOMVersion)).addRange(fieldnum(BOMVersion, RecId));
qbr.value('(fromDate = '+date2StrXpp(today())+')');
break;
The final SQL query will look like this (a fragment):
= BOMVersion.ItemId AND ((Active = 1)) AND (((fromDate = 13\12\2011))) JOIN * FROM BOM(BOM_1) ORDER BY BOM.LineNum ASC ON BOMVersion.BOMId = BOM.BOMId
The idea was taken from the AX forum (in Russian).
query, range
sumitax: AX Queries – Passing query range as parameter Blog bot DAX Blogs 0 29.06.2011 13:11
sumitsaxfactor: Using Methods Inside Query Range Blog bot DAX Blogs 0 05.05.2011 20:12
Jose Lorenzo: Out of range dates on demo data - Refresh 3, 3.5 and 4 Blog bot DAX Blogs 0 17.12.2010 00:12
emeadaxsupport: Passing UtcDateTime values in extended query syntax Blog bot DAX Blogs 0 10.05.2010 21:05
axaptafreak: Label for Query Range cannot be modified (still) Blog bot DAX Blogs 2 25.07.2007 10:09
Часовой пояс GMT +3, время: 03:19.
