Старый 13.01.2014, 22:11   #1
emeadaxsupport: Dynamics AX 2009 Enterprise Portal: How to display companies in company chooser in alphabetical order
Источник: http://blogs.msdn.com/b/axsupport/ar...cal-order.aspx
Suppose we have many companies in AX 2009 and to simplify the selection of the company list in the Enterprise portal, we can use the below code change to display the company names in an alphabetical order. This will help the AX users to save time in searching and selecting the company name.
Open Development workspace and navigate to AOT\Classes\Global\GetAllCompanies() by adding order by clause after Line 18:
//select all the companies in which current user's access level is higher than NoAccess
while select id,name from DataArea
//to order alphabetical add order statement
order by id
Exists join companyDomainList
emeadaxsupport: Microsoft Dynamics AX Enterprise Portal: How to add hyperlink field to AxGridView Blog bot DAX Blogs 0 20.07.2011 23:16
daxdilip: Tip How to Encode URL for Dynamics AX 2009 Enterprise Portal Link Blog bot DAX Blogs 0 15.12.2010 17:11
emeadaxsupport: How to change authentication of an existing Microsoft Dynamics AX 4.0 Enterprise Portal (EP) site to use IIS Basic Authentication Blog bot DAX Blogs 0 29.03.2010 21:05
Dynamics AX: Enterprise Portal Development in Microsoft Dynamics AX 2009 - Courseware Released! Blog bot DAX Blogs 0 30.07.2008 23:05
Часовой пояс GMT +3, время: 08:30.
