Старый 13.09.2014, 01:12   #1
ax_gfm_framework_team: Dimension defaulting - Part 7 (Advanced topics)
Источник: http://blogs.msdn.com/b/ax_gfm_frame...ed-topics.aspx
Introduction
Concluding this series of blog posts, this section covers additional defaulting patterns and APIs that can be used in advanced scenarios.
This blog post series includes:
DimensionDefaultingEngine
In the previous blog post, the DimensionDefaultingService class was described. It provides the common APIs needed for most defaulting needs. For scenarios not supported by the DimensionDefaultingService, the DimensionDefaultingEngine class can be used directly. This class provides all of the logic for the DimensionDefaultingService class.
The engine leverages a concept called dimension specifiers which is a map of dimensions and values obtained from default dimensions and ledger dimensions. The documentation for the DimensionDefaultingEngine can be found on MSDN.
Defaulting during segment entry
In most cases, the merging of default dimensions to a ledger dimension occurs before the user has begun editing the ledger account combination in a segmented entry control. In some circumstances, the form has logic to perform defaulting as the user enters each segment in the control. In order to do this, the form must respond to events raised by the segmented entry control.
To perform defaulting at entry leveraging the DimensionDefaultingEngine class, the segmentValueChanged() method on the segmented entry control is overridden. Defaulting can then be based on current values in the control providing values for other segments. This example in Figure 1 adds dimension values from the MainAccount table, merging with other values, as soon as a MainAccount is entered in the segmented entry control.
Figure 1: Sample segmentValueChanged() override to default during segment entry
This concludes this series of blog posts about dimension defaulting.
ax_gfm_framework_team: Dimension defaulting in accounting distributions, Part 3 - Splitting and defaulting using Financial dimension default templates and Main account allocation rules Blog bot DAX Blogs 0 18.12.2013 09:11
ax_gfm_framework_team: Dimension defaulting in accounting distributions, Part 1 - Introduction Blog bot DAX Blogs 0 17.12.2013 02:18
ax_gfm_framework_team: Ledger account combinations - Part 7 (Advanced topics) Blog bot DAX Blogs 0 16.02.2013 08:08
ax_gfm_framework_team: Ledger account combinations - Part 4 (Advanced rules) Blog bot DAX Blogs 0 16.02.2013 08:08
ax_gfm_framework_team: Step 3: Perform initial wiring to Source Document Framework – document classes Blog bot DAX Blogs 0 01.05.2012 18:11
Часовой пояс GMT +3, время: 16:20.
