Старый 19.05.2015, 18:11   #1
emeadaxsupport: Installing Reporting Services extensions on SQL Server 2014
Источник: http://blogs.msdn.com/b/axsupport/ar...rver-2014.aspx
Hello,
When installing Reporting Services extensions on SQL Server 2014 you may run into this error:
"Could not load file or assembly 'Microsoft.SqlServer.BatchParser, Version=10.0.0.0, Culture=neutral, PublicKeyToken=89845dcd8080cc91' or one of its dependencies. An operation is not legal in the current state. (Exception from HRESULT: 0x80131509)".
To resolve this issue you should install the following components of SQL 2008 R2 Shared Management Objects:
  • Microsoft® System CLR Types for SQL Server® 2008 R2
  • Microsoft® SQL Server 2008 R2 Shared Management Objects
  • Microsoft® SQL Server 2008 R2 ADOMD.NET
  • Microsoft® SQL Server 2008 R2 Analysis Management Objects
Go to the Microsoft® SQL Server® 2008 R2 Feature Pack download page: http://www.microsoft.com/en-us/downl....aspx?id=16978
Then, expand "Install Instructions" to see the download links.
I hope this is helpful!
Bertrand
ssrs
CRM DE LA CREME! CRM 4.0 Disaster Recovery Blog bot Dynamics CRM: Blogs 2 26.02.2016 08:23
dynamics-coe: Microsoft Dynamics AX 2012 Reporting Services – Integrated with SharePoint Farm Blog bot DAX Blogs 0 21.11.2014 13:11
emeadaxsupport: AX Content: Multiple instances of SQL Server Reporting Services (SSRS) on one computer Blog bot DAX Blogs 0 23.12.2013 18:11
emeadaxsupport: Unable to deploy AX 2012 Reporting Extensions on SQL Server 2012 Reporting Server Blog bot DAX Blogs 0 26.06.2012 23:12
emeadaxsupport: Reporting Extensions Installation Fails to install on SQL 2008 Reporting services after applying 959494 and 957312 Blog bot DAX Blogs 1 23.06.2011 14:27
Часовой пояс GMT +3, время: 18:49.
