Старый 10.09.2007, 23:22   #1
This procedure explains how to run SMTP component from NAV 5.0 in older versions. This was tested in Navision 4.0 SP3. Not all countries had NAV 5.0 a localized release.
If you don’t want this manual procedure of registering components you could also install NAV 5.0 client in same computer you are running NAV 4.0 SP3.
Manual Procedure:
1 – Copy “Microsoft.Navision.Mail.dll” and “Microsoft.Navision.Mail.tlb” from NAV 5.0 installation CD to NAV 4.0 client folder.
2 – You need to run regasmexe. This tool is located in “C:Program FilesTools;C:WINDOWSMicrosoft.NETFrameworkv2.0.50727”. When you run this tool you could add it to windows path or insert full path when running.
3 – In Navision client folder execute regasm Microsoft.Navision.Mail.dll /tlb:Microsoft.Navision.Mail.tlb
4 – Export fowling objects from NA 5.0 to NAV 4.0
Form – 409 SMTP Mail Setup
Codeunit – 400 - SMTP Mail
Table – 409 - SMTP Mail Setup
Now you can use codeunit SMTP Mail to send e-mails instead of using 3rd party components or writing new one in .NET.
Подробнее... http://dynamicsuser.net/blogs/nunomaia/arc...om-nav-5-0.aspx
Часовой пояс GMT +3, время: 06:59.
