Старый 14.09.2017, 13:11   #1
yetanotherdynamicsaxblog: Excel Applet not loading when working with D365 Office Add-in
Источник: http://yetanotherdynamicsaxblog.blog...n-working.html
This post is somewhat related to the post by Ievgen (AX MVP) on the Office Word integration not working with Dynamics 365 for Finance and Operations (Enterprise Edition).
If you try to connect Excel to an existing environment using the Microsoft Dynamics Office Add-in and all you see is the text "Load applets" after signing in, then it might very well be because the applets needs to be initiated from within the environment.
If you click the little flag at the bottom right, you will be able to open the messages and see the error "No applet registrations found".
Solution is simple. Open the D365 environment in your favorite browser (assuming your favorite browser is on the compatible list - hehe) and either search for the form (ie type in "Office") or navigate directly through System Administration, Setup and Office app parameters
If you see an emply grid, then the settings have not been initialized and that is the problem. Most likely you are missing settings for Office apps in general, so go ahead and initialize all parameters for all the grids accordingly.
Head back to Excel and try make it reload the applets (simply try add a trailing slash to the url). Hopefully you should get the expected result.
organicax: Add a new record from the Excel add-in for the new Dynamics AX Blog bot DAX Blogs 0 30.03.2016 01:18
emeadaxsupport: How to copy a budget to a new budget in AX 2012 using Excel Add-in Blog bot DAX Blogs 0 27.11.2012 15:11
nav4u: Dynamics NAV + Office Excel = Платформа Microsoft Blog bot Dynamics CRM: Blogs 0 04.12.2011 07:37
Nav developer: Outlook Add-in does not show up in Dynamics NAV 5.0, Dynamics NAV 5.0 SP1 and Dynamics NAV 2009 Blog bot Dynamics CRM: Blogs 0 15.10.2008 14:58
Karl Tolgu: The Atlas XL Microsoft Office Excel add-in by Globe Software uses the Dynamics AX Business Connector... Blog bot DAX Blogs 0 28.10.2006 16:40
Часовой пояс GMT +3, время: 11:57.
