Старый 09.02.2018, 03:19   #1
gustafwesterlund: Deleting a lot of records fast
Источник: http://gustafwesterlund.blogspot.com...ords-fast.html
A quick one today...
Needed to delete a couple of million records for a customer and the natural thing was to use the Bulk Deletion service, well, I turned it on and it was extremely slow. Only got about 10 records/s which would cause the entire delete to take over a week. I have checked with Micrsoft and this is not a bug, but it is working as designed and is not designed to be super fast. Personally I would like it to be when removing a lot of records cause sometimes you need to.
I also checked to see how fast the deletion would be with SSIS and Kingswaysoft. Used the following settings:
  • VM about 5 ms from the Dynamics 365 instance (important that it not be too far, use an Azure VM for this)
  • Used 64 threads
  • Used Execute Multiple batching with 10 (cannot use more that 10 if you are using a lot of threads, ie more than 2)
  • VM has 8 virtual cores and 32 GB memory
  • Loading in batches of 2000. Only loading the id-column, as that is all that is needed.
With this setup, I got somewhere around 345 records deleted per second. Which is a tad more than 34x faster than the bulk delete.
So, want to delete a lot of stuff, maybe Bulk Delete is not the way to go. Not yet anyway, let's hope Microsoft makes it faster!
Gustaf Westerlund
MVP, Founder and Principal Consultant at CRM-konsulterna AB
www.crmkonsulterna.se
dennis365foroperations: Tip: See what you need to see. Use your fast tabs more efficiently, including adding fields to the summary Blog bot DAX Blogs 0 09.01.2018 22:12
gustafwesterlund: Strange error when deleting managed Solution Blog bot Dynamics CRM: Blogs 0 06.03.2017 17:12
Microsoft Dynamics CRM Team Blog: Following and Unfollowing Records in CRM Blog bot Dynamics CRM: Blogs 0 28.10.2011 00:13
DeniZone: Deleting duplicate records in SQL Blog bot DAX Blogs 3 16.11.2009 13:26
Axapta Lessons: Merge Customer Records Blog bot DAX Blogs 0 28.10.2006 18:22
Часовой пояс GMT +3, время: 21:16.
