Старый 31.07.2018, 17:11   #1
d365technext: Flush the AOS cache from code. AX-2012
Источник: http://d365technext.blogspot.com/201...e-ax-2012.html
Well while working on a old project my project lead shared with me a very nice little trick.
Well the trick is to copy these three menu items, and then change the run from property to server. Now you can launch these menu items, and they will run on the server, therefore clearing the AOD, sys data, and dictionary, causing a refresh.
Menu item you can find on the below path
[Under Menu items > Action]
  1. SysFlushAOD
  2. SysFlushData
  3. SysFlushDictionary
instructorbrandon: Step by Step Performing a Code Upgrade from Dynamics AX 2012 to Dynamics 365 for Operations Part 3 Blog bot DAX Blogs 0 01.11.2017 02:16
Часовой пояс GMT +3, время: 18:55.
