Старый 20.11.2018, 14:11   #1
palleagermark: Thumbprint error when pasting thumbprint into the Regression Suite Automation Tool (RSAT) configuration
Источник: http://www.agermark.com/2018/11/thum...n-pasting.html
You can get an error like this when you paste the thumbprint, from your new certificate, into the configuration tool.
The reason for this is that the Certificate UI has an issue with a RichEdit control.
You should rather use a command prompt to list a thumbprint that is suitable for copy-n-paste.
Use "certutil -store my" for the machine certificates. The thumbprint can be located in the line that starts with "Cert Hash(sha1)".
Reference: https://support.microsoft.com/en-ca/...p-in-has-extra
palleagermark: Team Manager license and the Regression Suite Automation Tool Blog bot DAX Blogs 0 02.10.2018 12:12
powerobjects: Microsoft Dynamics 365 CRM Configuration Migration Tool Blog bot Dynamics CRM: Blogs 0 28.08.2018 01:18
emeadaxsupport: Cannot edit the WCF configuration out of the Dynamics AX 2012 client configuration Tool. Blog bot DAX Blogs 0 30.04.2015 18:12
Inside Dynamics AX 4.0: Licensing and Configuration Blog bot DAX Blogs 0 31.10.2007 11:40
Часовой пояс GMT +3, время: 05:32.
