Старый 03.09.2019, 10:12   #1
Ventainais is offline
Ventainais
Ax 12. R3 SSRS report BusinessLogic class method changes are not reflected in the report
Hello all!
I updated code in BusinessLogic class, recompiled it, redeployed the report and compiled INC CIL but the changes are not reflected in the report.
In the report I have a text-box with expression "getGroupTotal()" which returns an integer value 10 for testing, but when I generate the report it shows that methods previous calculated value.
If I change the expression to show any other variable without using BL methods then the report shows the change.
I tried to delete Visual Studio and Ax cache files, AOS restart but that didn't helped.
I would appreciate any help
If any other information is needed to help me, please ask.
dynamicsaxse: May-June 2017 release – Dynamics AX 2012 R3 Blog bot DAX Blogs 0 21.06.2017 00:12
emeadaxsupport: AX Performance - Analyzing key SQL Server configuration and database settings Blog bot DAX Blogs 0 28.09.2015 14:11
emeadaxsupport: AX Performance Troubleshooting Checklist Part 2 Blog bot DAX Blogs 0 09.09.2014 16:11
bojensen: Use a Dynamics AX display method in SSRS report | Arjen Stolk Blog bot DAX Blogs 0 20.03.2013 01:11
Часовой пояс GMT +3, время: 20:22.
