#6 |
Решать подобные проблемы "в уме", без снимков sysprocesses, результатов sp_lock, списка блокируемых объектов достаточно сложно. Не предоставлять достаточное количество информации - Ваше право
![]() Если ситуация воспроизводится при единственном пользователе в системе (он лочит сам себя) - да, проблема, надо разбираться. Если нет - тоже проблема блокировок, но уже совсем другая, и AOS тут не при чем. Что касается нескольких spid - немного конструктива (выдержка из Databases Advanced): Цитата:
For each 2-tier session Axapta starts at least three (3) connections against
the database: • Session used primarily for sequence-number generation and other system management tasks. This connection is referred to as the system connection. Reason for this session is to avoid update of “SystemSequences” to be part of a current active transaction, which would make it sequence-number generation a bottleneck in the system. • Application connection, which generally is used for running the business logic of the application. • Read-only connection, which is similar to the application connection, but no data manipulation operations are executed on this type of connections. Clients browsing data in Forms will typically use a read-only connection. • Optional user connections. The X++ language provides a number of ways to have “user defined” connections, which is accomplished by instantiating classes of type Connection, UserConnection, or OdbcConnection (refer to the “Axapta Developer’s Guide” for details). |
