Старый 28.10.2006, 18:22   #1
25,617 / 848 (80) +++++++
Axapta Lessons: Trapping keystrokes in a Form
Источник: http://axapta-lessons-learned.blogsp...s-in-form.html
How can we catch keystrokes in a Form?
When we want to catch the key pressed in a form we need to make some adjustments to the Form. These modifications consist of a few steps:
1. Add a macro that contains the values for the virtual keys.
2. Modify the ClassDeclaration of the Form.
3. Create a new method overruleFKeys on the Form to overrule the virtual keys.
4. Create a new method checkKeyPressed on the Form to capture the key pressed.
5. Override the Task method on the Form.
6. Override the Close method on the Form.
7. Override the Init method on the Form.
Let us have a look at an example hereafter. The Form we are going to create will just get two activeX controls, a clock and calendar.
The final Form defition will look as follows±
Overruling the virtual keys will result in no standard handling for the virtual keys anymore; this means that for instance pressing F1 will no longer lead to the help-functionality of Axapta, unless you implement it yourself again.
We are going to use the Windows DLL 'USER32' and it's function 'GetAsyncKeyState'. The function needs the value of the virtual key to be passed as a binary parameter, like for instance 0x72 for F3. When the key is pressed the function will return a value different from 0.
We can find the hexadecimal values for the keys here Virtual Key Codes
In the task-method we are going to catch taskId 520. When doing so, we will have to loop over all virtual keys to see if one of them was pressed. There is no other way to find out which one was pressed (if any) then to check them all. Since there are only a few of them, this won't lead to any performance problems.
We are going to achieve this by calling the method checkKeyPressed.
To be continued with detail explanation of the different steps.?*
За это сообщение автора поблагодарили: kashperuk (5).
Старый 29.10.2006, 01:16   #2
kashperuk is offline
kashperuk
Аватар для kashperuk
4,361 / 2084 (78) +++++++++
А картинки то не подтягиваются.
Старый 01.11.2006, 15:23   #3
Dron AKA andy is offline
Dron AKA andy
944 / 253 (10) ++++++
Таки подтянулись наконец-то...
Андрей.
Старый 01.11.2006, 15:57   #4
Картинки нормально подтягиваются в FF 1.5
и не подтягиваются в IE6, IE7, FF2.0
Оперу еще не проверял
Старый 01.11.2006, 16:22   #5
Russland is offline
Russland
Аватар для Russland
267 / 116 (4) +++++
Да, вроде, и без картинок всё ясно
Непонятно значение пп. 6, 7
В глухомани, в лесу Несмотря на красу Дни проводит Лиса Патрикевна. Я никак не пойму Отчего, почему Не пускают куму На деревню
Старый 01.11.2006, 16:50   #6
Сообщение от Russland Посмотреть сообщение
Источник указан. Щелкните и посмотрите оригинал с картинками.
Старый 01.11.2006, 17:05   #7
Russland is offline
Russland
Аватар для Russland
267 / 116 (4) +++++
И в оригинале не вижу
Старый 01.11.2006, 17:11   #8
Щелкните на ссылку Show/Hide this Post в оригинале
Старый 01.11.2006, 17:24   #9
Russland is offline
Russland
Аватар для Russland
267 / 116 (4) +++++
Да IE6.0 у меня
Теперь с вас скриншотик
Изображения
Старый 01.11.2006, 17:26   #10
kashperuk
Вот и скриншотик.
Изображения
Старый 01.11.2006, 17:35   #11
Russland is offline
Russland
Аватар для Russland
267 / 116 (4) +++++
Спасибо
Старый 01.11.2006, 17:50   #12
Russland is offline
Russland
Аватар для Russland
267 / 116 (4) +++++
http://axapta.mazzy.ru/lib/barcode/
Старый 01.11.2006, 17:58   #13
kashperuk
Это здесь причем?
Старый 01.11.2006, 18:16   #14
Russland is offline
Russland
Аватар для Russland
267 / 116 (4) +++++
Это здесь причем?
В наработке http://axapta.mazzy.ru/lib/barcode/ используется идея взятая из http://axapta-lessons-learned.blogsp...s-in-form.html
По данной ссылке можно увитеть код (возможно модифицированный) в текстовом, а не в графическом виде.
dax-lessons: Active directory in Axapta Blog bot DAX Blogs 0 27.08.2007 23:00
Axapta Lessons: FORM SalesTable (3): Add a document to the button Posting Blog bot DAX Blogs 0 28.10.2006 18:22
Axapta Lessons: FORM SalesTable (4): Add a document to the button Posting Blog bot DAX Blogs 0 28.10.2006 18:22
Часовой пояс GMT +3, время: 14:23.
