13.11.2006, 22:30 | #1 |
mfp: Building a layer file from XPO files
Источник: http://blogs.msdn.com/mfp/archive/20...xpo-files.aspx
============== So now you are using version control - and you just realized the master is no longer the AOD layer file, but instead a zillion of XPO files. Still you want to provide an AOD file to your consumers, as that is the way to deploy an AX application. Page 88 in Inside Dynamics AX 4.0 contains a description on how to build an AOD file from XPO files. In this section an SDK and a tool are mentioned. While we are working on providing you with the SDK for building a layer file, I can make the CombineXPOs.exe tool available. See the attached file. Usage: CombineXPOs.exe XPOfolder DestinationFile.xpo Example: CombineXPOs.exe USR myFile.xpo Files in the XPOFolder folder must match the AOT structure. This is automatically ensured when using AX version control integration. This posting is provided "AS IS" with no warranties, and confers no rights. ============== Источник: http://blogs.msdn.com/mfp/archive/20...xpo-files.aspx |
Теги |
xpo, импорт, полезное, сравнение, сравнение объектов |
Опции просмотра | |
