Старый 11.03.2003, 18:35   #21
Zabr is offline
Zabr
1,202 / 345 (14) ++++++
Ну господа, ну сколько можно-то...
(1) Axapta Database server:
COMPAQ
ML530 PIII Xeon 1000MHz, Tower
128 Reg SDRAM DIMM133 ALL256 Reg SDRAM DIMM133 ALL
Smart Array 5302/32 Controller, Ultra3, 2 Kanaler
Hot Plug Power Supply
9.1 GB Pluggable Ultra3 10.000 RPM2 disks in RAID 1 for NT 2 disks in RAID 1 for LOG 4 disks in RAID 0+1 for Data
Internal 50/100 AIT Tape Drive
IBM
xSeries 232, PIII 1.13GHz/133MHz, 512KB, Open bay, Rack
256MB PC133 ECC SDRAM RDIMM
IBM ServeRAID-4Mx Ultra160 SCSI Controller
385W power supply
IBM 18.2GB 10K-4 Ultra160 SCSI Hot-Swap SL HDD2 x 18.2GB Internal disks as Raid 1 for NOS and Archive Log2 x 18.2GB External disks asRaid 1 for Redo Log4 x 18.2GB External disks as Raid 1 for Data and Index
IBM 20/40GB DDS/4 4mm Internal Tape Drive –SCSIEXP300 Storage Expansion Unit
HP
HP ProLiant ML350R03, Xeon 2.2GHz, 512KB L2 cache, Rack mount
HP 256MB of advanced ECC PC2100 DDR SDRAM DIMM Memory Kit 256MB
HP Smart Array 532 Controller (2 channel, Ultra3, 64bit PCI)
HP 500W Hot Plug Redundant Power Supply Option Kit (EURO)
HP 18.2GB Wide Ultra3 SCSI 15000 rpm Drive (1")
2 disks as RAID 1 for OS+logs4 disks as RAID 0+1 for data
HP internal to external SCSI cable
(2) Axapta AOS :
COMPAQ
ML330 PIII 1133MHz 18GB Tower
Smart Array 431 Controller, Ultra3, 1 Kanal
IBM
xSeries 330, PIII 1.13GHz/133 MHz, 512KB, Open Bay, Rack
xSeries 256 MB 133 MHz ECC SDRAM RDIMM
IBM ServeRAID-4Lx Ultra160 SCSI Controller
IBM 18.2 GB 10K-4 Ultra160 SCSI Hot-Swap SL HDD
HP
HP ProLiant DL360R03, Xeon 2.4GHz, 533MHz FSB, 512KB L2 cache, Rack mount
HP 512MB of Advanced ECC PC2100 DDR SDRAM DIMM Memory Kit (2x256MB)
HP 18.2GB 15000 rpm U320 Universal Hard Drive (1")
2 disks in RAID 1 for OS+data
Старый 12.03.2003, 09:45   #22
La_Dimas is offline
La_Dimas
А я уже и не чаял увидеть простые цифры вместо замысловатых букв.
Спасибо, что укрепили меня в сделанном выборе. Одно я понял: эту тему можно жевать ну очень долго.
Еще раз спасибо за ответ.
Старый 23.09.2003, 16:22   #23
kalex is offline
kalex
Приветствую всех!
Очень интересует ответ на вопрос:
Какие минимальные аппаратные требования для тонкого\толстого клиентов Аксапты?
Существует ли в природе документ, где это написано?
Старый 23.09.2003, 16:33   #24
Изначально опубликовано Zabr
Этим рекомендациям уже года два. Делайте поправки на развитие техники.
документ существует на technet.navision.com
Общая рекомендация.
На клиенте сама Аксапта будет работать с такой же скоростью, что и МС Офис.
На сервере важными параметрами являются память и количество физически-независимых дисков (впрочем, как и для любой другой СУБД)
Старый 23.09.2003, 16:42   #25
Михаил Андреев is offline
Михаил Андреев
Компания АМАНД
1,300 / 239 (10) ++++++
2 mazzy.
Сергей! Человек спросил требования к КЛИЕНТУ Аксапты. На сервер требования он, похоже, уже нашел.
2 kalex.
Специального мануала с требованиями к клиенту не видел. Может, где и есть.
По опыту знаю, что для трехуровневого клиента ничего не надо, кроме работающей операционной системы (Windows, разумеется).
А вот для двухуровневой критичными становятся скорость процессора, чуть больший объем памяти (128МБ обычно хватает, если W98, или 256 для 2000/XP) и, очень важно, скорость сетки (на 10 МБ уже десяток пользователей почувствуют разницу).
Поэтому ставить рекомендую сразу трехуровневую и не заморачиваться с требованиями
Михаил Андреев
https://www.amand.ru
Старый 26.09.2003, 12:35   #26
glibs is offline
glibs
Сотрудники компании It Box
4,942 / 911 (40) +++++++
Изначально опубликовано Михаил Андреев
...Человек спросил требования к КЛИЕНТУ Аксапты...
Вот тут есть информация. Правда, неофициальная...
http://technet.navision.com/workspac...tribId=1&wso=1
glibs®
Старый 28.10.2003, 10:54   #27
al is offline
al
Требования к аппаратуре из официальной брошюры Navision "Сила интеграции" (июнь 2002):
200 МГц Pentium II с 64 Мб ОЗУ
Старый 10.11.2003, 23:42   #28
komar is offline
komar
Шаман форума
Аватар для komar
5,571 / 600 (32) +++++++
Требования к "толстому" клиенту Акзапты можно взять аналогичными клиенту Аттейна. Требования к "тонкому" клиенту соответствуют требованиям MS Office.
Старый 21.07.2004, 10:57   #30
azhukov is offline
azhukov
Совершенно верно Скорость сервера зависит не от бренда, а от администратора. На полном серьезе.
А еще больше от программиста, написавшего код
Старый 23.08.2004, 18:58   #31
Serj is offline
Serj
Я догадываюсь, что поднимаю тему уже далеко не в первый раз, и всё же.
Помогите пожалуйста определиться с железом для Аксапты. Ситуация примерно такая: сейчас есть некий аналог Галактики, планируется переход на Аксапту…
Руководство начало спрашивать какие примерно ожидаются затраты на железо.
Кол-во пользователей примерно 150, очень активных около 10, просто активных человек 20. Работают в базе одновременно 80 человек. Будет ли расти количество Пользователей, пока неясно… Сейчас имеется один сервак с базой (на двух третьих пнях) и 4 терминала. Весь офис работает через WTS.
Посему вопросы такие: Какое железо придётся покупать (скажем в не брендовом эквиваленте), желательно как можно полнее (процы, оперативка, кол-во отдельных SCSI винтов под то-то и то-то… и т.д.). Ещё раз извиняюсь за измусоливание этой темы… Заранее благодарен.
Старый 23.08.2004, 22:56   #32
George Nordic is offline
George Nordic
Аватар для George Nordic
4,480 / 1255 (50) ++++++++
Записей в блоге: 9
Чем больше - тем лучше. Кто-то предпочитает IBM, кто-то Intel, я предпочитаю HP/Compaq... хотя он и "порадовал" общественность отвратительным финансовым отчетом Советую обратить внимание именно на брэнд: внедрение - штука довольно серъезная, и экономить - себе вредить. Мы тоже шли по пути "наименьших затрат".. Кто ж знал, что фирма, у которых мы покупали сервера, тоже, своего рода "русский брэнд", решит съэкономить на SCSI дисках??Уже (за 1 год) 3 штуки (треть) вылетело насмерть А уж коли на диске (на памяти, процессоре )написано HP - значит, эта фирма за это оборудование и отвечает!
Но, по существу... Сервер БД прожорлив до всего. Процов - хотя бы 2 Xeon'a памяти - 8Гб... Дисках... о дисках.. 1- под систему, 1 - кэш , 1 - Oracle (MS SQL), 3- логи + под данные... почитайте форум у mazzy, литературу соответствующую.. Желательно все крупные таблицы - на разные диски. В общем, лучше куча маленьких дисков, чем немного больших.. штуки 3 - как минимум. Корзина, короче. АОС (аосы)... те больше до процессоров поржорливы, чем до памяти.. можно - блэйды поставить... даже наши вроде начали неплохие делать... 2 - 4х Xeon.. 2 - 4 Гб. 3 диска. Ну, в этим можно начинать
С Уважением,
Георгий.
Старый 13.08.2012, 18:32   #33
kostass is offline
kostass
Подбирая железо для выделенной машины, под сервер пакетных обработок, от чего стоит отталкиваться? Не осталось ли у кого рекомендаций Microsoft для AX3.0 или AX4.0?
Axapta 3.0 SP6
Последний раз редактировалось kostass; 13.08.2012 в 18:35.
Старый 14.08.2012, 09:11   #34
Dark Light is offline
Dark Light
Академический интерес: а все всегда используют именно Intel Xeon? Нет ни у кого опыта применения процессоров AMD Opteron? Если есть, то каких (старых с полноценными ядрами или новых с двуядерными модулями) и как они себя показывают на Аксапте?
Старый 14.08.2012, 10:32   #35
oip is offline
oip
Axapta
2,564 / 1416 (53) ++++++++
Записей в блоге: 1
Сообщение от kostass Посмотреть сообщение
Осталось. Вот для 3.0:
Axapta Hardware Guide For Environments Less Then 100 Users
7. Axapta Batch Server
A typical Axapta Batch Server that supports transactions that do not exceed 5,000 lines per module is as follows:
Hardware
Processors 2x3.6 GHz 1MB L3 Cache Intel® Xeon Processors MP RAM 4 GB
Internal Storage 2x36GB Ultra 3 (15KRPM) RAID1
Internal Storage HBA Array Controller
Network Interface Card (NIC) Server Adapter 1GB Fibre
OS and Middleware
Windows Server 2003 Standard
Microsoft Batch Server Version 3.0 Service Pack 3
Старый 14.08.2012, 11:07   #36
kostass is offline
kostass
Спасибо oip.
Я правильно понял, имеется в виду 5000 строк кода X++, обрабатываемого на сервере?
Axapta 3.0 SP6
Старый 14.08.2012, 11:10   #37
oip is offline
oip
Axapta
Записей в блоге: 1
Не строк кода X++, а строк документов. В час.
Старый 14.08.2012, 11:17   #38
kostass is offline
kostass
Сообщение от oip Посмотреть сообщение
Да, это гораздо логичнее
Axapta 3.0 SP6
Старый 14.08.2012, 11:18   #39
Maximin is offline
Maximin
NavAx Club
415 / 361 (13) ++++++
Почитайте мой пост Подбор оборудования для AX 4/2009 там будут названия документов, которые надо гуглить. Если до конца дня не найдете, напишите в личку - у меня есть их копии дома.
Кстати насчет Оптеронов - отличная штука для БД Аксы, имел дело. Весьма шустрая, и в современном состоянии (Bulldozer архитектура) - недорогая и отлично подходящая под OLTP при этом. В десктопных приложениях они, чаще всего, сливают, но именно в тестах Database раскрываются во всю мощь.
Вот под АОС что лучше сейчас уже не скажу. Нужно тестировать. Если есть деньги можно взять Xeon, в крайнем случае будет просто тупо дороже, чем могло бы.
Жизнь прекрасна! Если, конечно, правильно подобрать антидепрессанты...
Последний раз редактировалось Maximin; 14.08.2012 в 11:20.
За это сообщение автора поблагодарили: Dark Light (1).
Старый 14.08.2012, 19:10   #40
Vadik is offline
Vadik
Аватар для Vadik
3,631 / 1853 (69) ++++++++
Сообщение от Maximin Посмотреть сообщение
Ммм, с большими оговорками, я бы так сказал. По производительности "на ядро" они традиционно слабее интеловских процессоров (не холивар - просто констатация фактов) и основным преимуществом является (являлось) существенно бОльшее количество ядер на сокет и относительная дешевизна. В свете перехода на лицензирование "по ядрам" (вместо "по сокетам") для SQL Server 2012 стоимость "недорогого железа" становится "о" малым по сравнению с совокупной стоимостью системы (железо+софт), так что для топовых (серия 62XX - до 16 ядер на сокет) процессоров AMD пришлось выбивать у MS специальную скидку 25% в виде SQL Server 2012 Core factor table, чтобы брали хоть как-то
Вы не подумайте чего плохого - процессоры и машины на них построены прекрасные, но что касается закупки системы на оптеронах под СУБД - "думайте сами, решайте сами". Под все прочее (AOS-ы, или что еще лучше виртуализацию) - пуркуа бы и не па, как говорится. Тестируйте, считайте, покупайте
-ТСЯ или -ТЬСЯ ?
ax3.0, ax4.0, оборудование, пакетная обработка, пакетный сервер, производительность
Как сильно модифицировано ваше приложение Аксапты? mazzy DAX: Прочие вопросы 30 14.04.2011 17:26
Вставка строк в таблицы Аксапты сторонними средствами Андре DAX: База знаний и проекты 1 07.05.2009 16:49
Экспорт / импорт Help topics и запуск второй сессии Аксапты из-под себя DmitrySt DAX: Программирование 0 25.11.2004 00:22
Железо для аксапты Sergey_NVKZ DAX: Администрирование 19 15.12.2003 04:35
Установка Аксапты Новичок DAX: Администрирование 1 08.01.2002 10:30
Часовой пояс GMT +3, время: 00:02.
