05.03.2010, 17:05 | #1 |
AX 2009 Technical Journal: AX Load Balancing
Источник: http://ax2009tech.blogspot.com/2010/...balancing.html
============== A tree tiered architecture has been around since AX 4.0. In AX 2009 you have 3 possible AOS configurations:
And information from Microsoft states that a dedicated load balancer only is needed when you have more than 4 AOS instances in the same cluster. All combinations in the client configurations will work (no difference wheter you only reference the dedicated load balancing instance and/or all AOS instances). Any comments around this matter will be appreciated. Источник: http://ax2009tech.blogspot.com/2010/...balancing.html
Опции просмотра | |
