Старый 21.06.2011, 19:11   #1
25,626 / 848 (80) +++++++
axinthefield: Update multiple records with 'Fill Utility'
Источник: http://blogs.msdn.com/b/axinthefield...l-utility.aspx
Fill Utility:
The Fill utility enables authorized users and/or administrators to mass-update records, similar to the find and replace functionality. This utility assists administrators or users during implementations or when business process changes affect multiple records.
Caution: 1) It's recommended practice to take backup of entire database before performing this 'Fill Utility' operation.
2) It's recommended to use this feature during implementations (or) when business process changes affect multiple records.
Enable configuration key:
Path: Dynamics Ax > Administration > Setup > System > Configuration > Under Administration tree (Enable 'Fill Utility' option)
Note: Please follow the standard procedure to enable this configuration. This may require restart of AOS & Data dictionary sync to make sure changes take immediate effect.
Fill Utility usage:
Open the form that contains the field to update.
Example: Dynamics Ax > Accounts Receivable > Common forms > Customer details > Select required customer record > payment tab
Right click on the field 'Ledger account' field > Record info
Click button 'Fill Utility'
We can select the criteria here
Click button 'OK'
Validate the records and click 'OK'
Select new 'Terms of payment' = N045 (here we have to specify new terms of payment)
Click 'OK'
Caution: Be aware that changing numerous records at the same time can be time-consuming.
Fill Utility log:
Path: Dynamics Ax > Basic > Inquiries > Fill Utility log
Security key: Adminfillutility
This completes 'Fill Utility' feature details from usage.
fill utility
axinthefield: Choosing a Single Deployment or Multiple Deployments of AX2009 Blog bot DAX Blogs 0 15.06.2011 03:25
Rahul Sharma: Modify Dynamics AX Standard Excel Import to Include - Update existing records - rule Blog bot DAX Blogs 0 04.06.2011 02:12
Khue Trinh: Fill Utility in AX2009 Blog bot DAX Blogs 0 28.09.2010 10:05
Dynamics AX Sustained Engineering: Fill Utility incorrectly updating a field in a form datasource Blog bot DAX Blogs 1 27.05.2010 23:05
Khue Trinh: Fill Utility in AX2009 Blog bot DAX Blogs 0 10.07.2009 10:05
Часовой пояс GMT +3, время: 05:29.
