Старый 20.01.2012, 23:13   #1
25,631 / 848 (80) +++++++
axinthefield: AOS Load Balancing
Источник: http://blogs.msdn.com/b/axinthefield...balancing.aspx
I've been questioned several times recently about AOS load balancing in Dynamics AX, and there seems to be quite a bit of confusion about how to properly configure AX for AOS load balancing, as well as high availability. Here are a few clarifications that apply to Dynamics AX version 4.0, AX 2009 and AX 2012:
Facts:
  • The AX client configuration determines which AOS instance that client will connect to.
  • If multiple AOS instances are listed, it will simply go down the list until it establishes contact.
  • If the contacted AOS instance is part of a load balanced cluster, that AOS will act as the load balancer. If not, the contacted AOS is used.
  • The load balancing logic is based on a count of current user sessions, and also takes into consideration the max concurrent sessions defined for the instance on the cluster.
  • If you have only one AOS instance listed in the client configuration, you have created a single point of failure. If no connection is established with that AOS, the client connection will fail, even if that AOS instance belongs to a cluster that has other AOS instances available for connection.
Recommended Configurations:
  • Every client configuration should point to all AOS instances in the cluster, thus eliminating the single point of failure.
  • Those AOS instances listed in the client configuration should belong to the load balanced cluster
  • A dedicated load balancer should only be used in high volume scenarios
AX 2009 Technical Journal: AX Load Balancing Blog bot DAX Blogs 0 05.03.2010 17:05
Solutions Monkey: Screencast - How to set up Enterprise Portal (EP) in a Network Load Balancing (NLB) MOSS 2007 cluster Blog bot DAX Blogs 0 14.08.2009 11:05
daxis: Troubleshooting blocked SPIDS in AOS Blog bot DAX Blogs 0 01.04.2009 18:05
Arijit Basu: AX 4 AOS Basics: [Level 100] Blog bot DAX Blogs 0 18.11.2007 14:30
Часовой пояс GMT +3, время: 16:20.
