ax-erp: What methods are called when a runbaseBatch process is executed?
Источник: http://microsoft-dynamics-ax-erp.blo...lled-when.html
============== It can be handy to have detailed knowledge on the runbaseBatch class. In this tutorial I will explain the calling sequence of the RunBaseBatch class with a query (select button). We will start this process with a static construct function that will force the runbaseBatch process to run on the server. In the left column of below table is shown the method name of the runbase batch and the location where it is running. The order of the lines in the table is also the order AX will execute the methods. (Note: The runbase mechanism calls sometimes methods twice, these duplicate call are removed from this list.) Server construct Our constructor will execute the new method Server new Server prompt Server unpack Server showdialog Server pack Client new Reconstruct the class on the AX client Client unpack Get the values from the previous run Client canGoBatch Do we need to show the batch tab page Client prompt Client showdialog Do we need to show dialog Client caption Set the caption of the dialog Client queryRun Get the query object (if exist) Client showQueryValues Do we need to query values on the general tab page of the dialog Client showQuerySelectButton Do we need to query select button on the dialog Client showDefaultButton Do we need default button Client showClearButton Do we need clear button Client dialog Build your dialog (don’t remove super otherwise you don’t see the batch tab page Client dialogPostRun Used to make additional modification to the dialog (field High), set overload methods Finally our dialog appears on the screen. ![]() Next we press the OK button. The next methods of the runbaseBatch will be executed: Client getFromDialog We get the values from the dialog , don’t remove super otherwise batch and select info is gone Client validate Check if all dialog values are valid Client pack Store the values in the SysLastValue table Server unpack Readout the values from the SysLastValue table Server canGoBatch Check if we have to run in batch Server run Run the process (can be from batch process) Источник: http://microsoft-dynamics-ax-erp.blo...lled-when.html
Опции просмотра | |
