Старый 04.02.2014, 01:12   #1
25,644 / 848 (80) +++++++
emeadaxsupport: AX2012: Error when downgrading the AX server kernel
Источник: http://blogs.msdn.com/b/axsupport/ar...ax-kernel.aspx
Description:
It can happen that you need to downgrade the AOS kernel in a system. Depending on the build you are going back to, you might get an error message.
Error message:
Object Server 01: Fatal SQL condition during
login. Error message: "The internal time zone version number stored in the
database is higher than the version supported by the kernel (4/1). Use a newer
Microsoft Dynamics AX kernel."
Solution:
You need to change the value for the column value SYSTIMEZONESVERSION in the table SQLSystemVariables. If you look in
the event viewer you can see that it finds the value 4, but expected 1 (4/1).
So the solution is to change the value to 1.
Author: Kim Truelsen
Date: 3/2-2014
emeadaxsupport: AX Content: The Microsoft Dynamics AX help server - how it works and how to customize it Blog bot DAX Blogs 0 05.11.2013 21:11
emeadaxsupport: Opening a Report on AX 2012 raises infolog error: The default Report Server Configuration ID could not be found in the SRSServers table. Blog bot DAX Blogs 0 02.12.2011 00:13
emeadaxsupport: Error "Cannot access a disposed object" when deploying AX 2009 Enterprise Portal on a SharePoint 2010 server Blog bot DAX Blogs 0 01.10.2010 20:05
emeadaxsupport: Renaming an AOT object in Dynamics AX 2009 that is under source control with Team Foundation Server Blog bot DAX Blogs 0 06.10.2009 02:05
Часовой пояс GMT +3, время: 00:06.
