organicax: RFQ expiration date – days offset
Источник: https://organicax.com/2017/02/03/rfq...e-days-offset/
============== If you are setting up request for quotes it helps to go through the parameters to see if they can help save you some time updating fields. One is the expiry date. You can set a default adjustment to the expiry date in the procurement parameters. This will default to the header and get pickup in the lines. Here is a quick overview. AX2012 R3 CU11 Cheers Lachlan Filed under: Procurement and sourcing ![]() Источник: https://organicax.com/2017/02/03/rfq...e-days-offset/
Опции просмотра | |
