Старый 23.08.2018, 21:12   #1
25,644 / 848 (80) +++++++
emeadaxsupport: IDMF – Configuration Setting – UpdateMasterSyncTablesPostMetaDataSync
Источник: https://blogs.msdn.microsoft.com/axs...tmetadatasync/
Consider a scenario where you are using IDMF 2.0, and you find that after each IDMF Metadata sync the Master table list gets refreshed and you then have to manually sort out the list each time by unchecking/checking tables as Master tables. Well, there’s a simple way to change that default behaviour: 1. Update AXDataManagementSchedulerService.exe.config... Read more
emeadaxsupport: IDMF - How to troubleshoot job status issues like Last run result = Error Blog bot DAX Blogs 10 04.11.2015 16:09
emeadaxsupport: AX Performance Troubleshooting Checklist Part 1B [Application and AOS Configuration] Blog bot DAX Blogs 0 05.09.2014 21:11
Inside Dynamics AX 4.0: Licensing and Configuration Blog bot DAX Blogs 0 31.10.2007 11:40
Часовой пояс GMT +3, время: 13:50.
