Старый 24.01.2019, 07:17   #1
25,644 / 848 (80) +++++++
waldo: Where to find the Microsoft Dynamics 365 Business Central (and NAV) Docker Images
Источник: https://dynamicsuser.net/nav/b/waldo...-docker-images
While I was writing my previous blogpost, I was wondering what the actual Docker repos are today. Basically:
when we want to set up a certain Docker container, where can I find it?
Well, easy. Just read this blogpost from Freddy, the Docker-God from Microsoft. But, while most info on it is still very valuable, you might also notice that some of the repos our outdated. That’s why I decided to create some kind of up-to-date (and sometimes a little bit into the future) overview on what images/repos Freddy makes available for us.
This is what I found out:
mcr.microsoft.com/businesscentral/onprem
  • What?
    • OnPrem images of Microsoft Dynamics 365 Business Central
    • You can’t find any image of Dynamics NAV – so only Business Central versions are available here
    • From 13.0 (which is RTM) until …
  • Why?
    • Use these for your OnPrem cases. They are preconfigured with OnPrem settings, and behave like it would OnPrem.
  • List of images: https://mcr.microsoft.com/v2/busines...prem/tags/list
  • Some Examples
    • I usually use Belgian images, so what I would simply do is take the latest Belgian version by using this image: “mcr.microsoft.com/businesscentral/onprem:be
    • Or if you need to be version-specific, you have the option to provide the CU-number, or version, like these options would be the same:
      • mcr.microsoft.com/businesscentral/onprem:cu2
      • mcr.microsoft.com/businesscentral/onprem:13.2.26556.0
    • Or, if you don’t want W1, you can specify country-versions on top of that
      • mcr.microsoft.com/businesscentral/onprem:cu2-be
      • mcr.microsoft.com/businesscentral/onprem:13.2.26556.0-be
    • For more examples, please visit Freddy’s blogpost that I mentioned above.
mcr.microsoft.com/businesscentral/sandbox
  • What?
    • This has quite the same list as the OnPrem version, but the images are preconfigured like Business Central would behave in the cloud.
    • No versions earlier then 13.0 (Business Central), so no “Dynamics 365 for ..(blabla).. Business Edition”)
    • You can’t find any “future” versions here, which you might need to prepare your app for the next version of NAV – see below for where you can find those.
  • Why?
    • It’s great for learning, demoing, developing against SaaS-related environments. So for Apps, but also for “Per Tenant Customizations”.
  • List of images: https://mcr.microsoft.com/v2/busines...dbox/tags/list
  • Some Examples
    • If you want to enable the “Experience Levels” behaviour like in SaaS, you need these images
    • The same tagging-strategy applies here as well
mcr.microsoft.com/dynamics-nav
  • What?
    • The Docker Repo refers to “Dynamics NAV”, so it’s clear that here you can find “the old stuff”:
      • NAV2016..2018
    • No current versions (nor future versions) of Business Central can be found in this repo!
  • Why?
    • Because we all might still have customers on “older” versions
  • List of images: https://mcr.microsoft.com/v2/dynamics-nav/tags/list
    • As this repo isn’t available yet, this URL is just an assumption..
  • This repo is (going to be) a replacement for this repo on Docker Hub: “microsoft/dynamics-nav”. At this point, it doesn’t exist yet, but it will in the near future replace the one on DockerHub.
  • Example
    • I use it a lot for localization-services I do for certain partners. It’s just setting up a Docker image of “Dynamics-NAV” from a certain version/localization to get to the txt-files. Easy!
bcinsider.azurecr.io/bcsandbox
  • What?
    • “bcinsider” means it’s protected from anyone that are not given access as an “insider”.
    • This specific one, is the next (minor) release of Business Central.
    • Branched out from the master-branch (see below) to start creating a “stable” release
  • Why?
    • If you have an app on appsource, this is a way to be prepared if your app will build against the next release. I strongly recommend doing so, not only for your apps on appsource, but also for your customers with “Per Tenant Customizations”.
  • List of images
    • As far as I know, it is not possible to get to a list of all the images – not even with PowerShell ;-).
  • To gain access to the bcinsider-repos (also the next one I will talk about), you need to become an insider. More information you can find on Microsoft Collaborate.
bcinsider.azurecr.io/bcsandbox-master
  • What?
    • Also an insider release you need to get access for by Microsoft
    • This is the master-branch – which basically means the next major version of Business Central. You have access to a daily build of the current master branch
    • Also referred to as “unstable” branch.
  • Why?
    • To look even further in the future – to prep you of upcoming features in the language or the application.
  • List of images
    • As you might have expected – also for this repo, I have no way to provide a list of image-tags.
  • Gain access the same way as mentioned above.
microsoft/bcsandbox
  • You will see that it still works, but at one point, it will be deprecated, so it’s time to update your scripts to be using the one that I mentioned above:”mcr.microsoft.com/businesscentral/sandbox”
  • Also this one still works and will be deprecated and replaced by “mcr.microsoft.com/dynamics-nav”. When writing this blog, this hasn’t happened just yet, so you might still need this repo today, to find all NAV2016..NAV2018 versions.
  • List of images:
Hope it was somewhat clear – enjoy!
waldo: Microsoft Dynamics 365 Business Central is released @ Directions NA Blog bot NAV: Blogs 0 05.10.2018 20:12
waldo: Microsoft Dynamics 365 Business central – Resources Blog bot NAV: Blogs 0 02.04.2018 11:11
saurav-nav: Microsoft Dynamics 365 Business Central - Day 1. Blog bot NAV: Blogs 0 16.03.2018 06:13
waldo: Microsoft Dynamics 365 Business Central – some more info Blog bot NAV: Blogs 0 15.03.2018 04:47
waldo: Microsoft Dynamics 365 Business Central Blog bot NAV: Blogs 0 14.03.2018 10:11
Часовой пояс GMT +3, время: 22:01.
