Старый 10.02.2009, 15:05   #1
25,626 / 848 (80) +++++++
Dynamics AX Sustained Engineering: Compatibility Testing
Источник: http://blogs.technet.com/dynamicsaxs...y-testing.aspx
Dynamics AX Sustained Engineering executes Quarterly External Dependency Tests to provide information to customers and partners on the existing products releases. In this blog you shall get to hear the latest compatibility matrix on AX 3 SP6, AX 4.0 SP1 and SP2 , AX 2009RTM and AX 2009 SP1. Check this space often to keep yourself up to date on our latest compatibility tests.
For more specific information contactdaxsecom@microsoft.com
Thanks,
DAX Sustained Engineering
Dynamics AX Sustained Engineering: SQL Server 2005 sp3 & SQL Server 2008 with Dynamics AX Blog bot DAX Blogs 0 12.02.2009 06:08
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 2009 Service Pack 1 Released Blog bot DAX Blogs 5 21.11.2008 17:00
Dynamics AX Sustained Engineering: Dynamics AX 2009 Patching Blog bot DAX Blogs 0 08.10.2008 10:05
Часовой пояс GMT +3, время: 00:35.
