Старый 20.04.2009, 10:56   #1
soin is offline
soin
AX2009 Reporting Services...
Добрый день.
Кто нибудь развертывал AX2009 RS на 64-битной платформе?
Старый 20.04.2009, 11:26   #2
Poleax is offline
Poleax
Аватар для Poleax
1,353 / 595 (22) +++++++
Записей в блоге: 34
soin
Я устанавливать не пробовал, но могу поучаствовать в разборе проблем
Интересно, может скоро самому придется ставить.
В чем собственно проблема?
Обще познавательные линки:
  1. http://gatesasbait.spaces.live.com/B...B9F5!235.entry
  2. http://msdynamicsax.wordpress.com/20...d-ms-sql-2008/
  3. Microsoft Dynamics AX 2009 Installation Guide
    http://dynamicsuser.net/media/p/137794.aspx
    Install required components
    Reporting extensions
    Checklists for installing the reporting extensions
    Install prerequisites on the report server
    Configure Reporting Services
    Configure Reporting Services 2005 on Windows Server 2008
    Update the Reporting Services configuration file
    Install the reporting extensions
    Deploy reports
    Set up the reports
  4. Installing AX 2009 Reporting Extensions in MSSQL 2008 & WIN 2008
    http://daxguy.blogspot.com/2008/12/i...xtensions.html
    When we try to install AX 2009 SP1 Reporting Services on a PC running SQL 2008,we get an error saying that MSSQL 2005 SP2 is required. Well there is a solution to this issue which is as follows:
    1. Locate the AX Reporting services dll from the extracted AX 2009 SP1 folder
    [\\AX2009SP1\support\axsetupresources\microsoft.dynamics.setup.reportingservices.dll;File Version - 5.0.1000.52]
    2. Extract the AX 2009 .iso to a shared folder
    3. Copy the microsoft.dynamics.setup.reportingservices.dll into the folder:
    \\DynamicsAX\Msi\Components32\Program Files\Microsoft Dynamics AX\50\Setup
    \\DynamicsAX\Msi\Components64\Program Files\Microsoft Dynamics AX\50\Setup
    4. It will ask to replace the existing dll having File Version - 5.0.593.0. Say Yes and replace.
    5. Then Install AX Reporting Services extensions. It works fine and the Reporting Extensions are installed nice.
Последний раз редактировалось Poleax; 20.04.2009 в 11:41.
Старый 20.04.2009, 11:45   #3
soin is offline
soin
Статус системы такой:
1) Windows Server 2008 x64
2) SQL Server 2008 x64
3) Office Server 2007 x64 (Sharepoint Portal Server)
4) Dynamics AX 2009 SP1 RU-1
5) Ролевой центр установлен.
Нужно сделать развертывание отчетов на репорт-сервере
Проблема в отсутствии следующих файлов (они идут в составе Visual Studio 2008).
1) Al.exe (Assembly Linker)
2) Alink.dll
3) alinkui.dll
Речь идет ествественно о 64-битных версиях
Старый 20.04.2009, 12:19   #4
Poleax is offline
Poleax
Аватар для Poleax
Записей в блоге: 34
Предлагаю переустановить .NetFramework 3.5.
Есть шанс что исправит.
+ надо поставить Framework\v2.0.50727 там есть alinkui.dll
Framework\v1.1.4322\al.exe
Microsoft .NET Framework 3.5 Service Pack 1
http://www.microsoft.com/downloads/d...displaylang=en
Full Package
To download the full package, rather than the bootstrapper, click on the link below:
.NET Framework 3.5 Service Pack 1 (Full Package)
Последний раз редактировалось Poleax; 20.04.2009 в 12:43.
Старый 20.04.2009, 13:11   #5
soin is offline
soin
Это не помогает.
Потому и написал - что может у кого развернуто это жело на х64 - и можно будет файлы позаимствовать...
Собственно в основном нужен только AL.EXE
без этого файла не могу выполнить следующие пункты:
Сообщение от Poleax
1) Deploy reports
2) Set up the reports
Последний раз редактировалось soin; 20.04.2009 в 13:14.
Старый 20.04.2009, 13:22   #6
glibs is offline
glibs
Member
Сотрудники компании It Box
4,942 / 911 (40) +++++++
Помнится, по этому поводу качал я студию.
Я спросить хотел, а не посоветовать. А установкой студии эта проблема не решается?
Я ее так решал, но скорее всего на х86 (точно не уверен). Так что насчет х64 самому интересно.
glibs®
Старый 20.04.2009, 13:31   #7
fed is offline
fed
Аватар для fed
2,899 / 5688 (195) ++++++++++
Возможно я не прав, но по моему на самом деле надо качать не студию, а всего-лишь .NET SDK. Он есть для версии .x64 и ia64. Кроме того (что забавно) у SDK номер версии всего-лишь 2.0. То есть - не смотря на выход .net 3.0 и .net 3.5, платформа осталась от версии .net 2.0, а все примочки свелись к дополнительным библиотекам. Так что не удивляйтесь что на поиск фразы ".net sdk", google отправляет на версию 2.0...
Старый 20.04.2009, 13:34   #8
soin is offline
soin
Такая мысль мелькала. Да и есть у меня VS 2008 Team Edition.
Я просто зря систему засорять не хочу.
Вот я сейчас нашел al.exe в самой папке Windows (подпапка SysWOW64) - однако при развертывании репортов (точнее из сборке) выдается ошибка по библиотеке alink.dll
Видимо версия al.exe не соответствует версии alink.dll
Причем последняя идет в составе Framework
Я надеялся что естб кто-то - кто уже уставил все это на х64 и думал взять эти файлы. Там они должны подходить друг к другу.
Старый 20.04.2009, 13:34   #9
Poleax is offline
Poleax
Аватар для Poleax
Записей в блоге: 34
Install prerequisites on the report server - 59 Страница
На сколько этот пункт выполнен?
Microsoft Visual Studio 2008 Shell (isolated mode) Redistributable Package
Последний раз редактировалось Poleax; 20.04.2009 в 13:37.
Старый 20.04.2009, 13:44   #10
soin is offline
soin
Попробую поставить .NET SDK x64
Будем надеяться
Вообще в установке AX2009 пока это самый геморойный вариант. Sharepoint и RoleCenter куда легче ставятся...
Старый 20.04.2009, 13:50   #11
soin is offline
soin
Сообщение от Poleax Посмотреть сообщение
Выполнен
Старый 20.04.2009, 13:57   #12
Poleax is offline
Poleax
Аватар для Poleax
Записей в блоге: 34
soin
Microsoft Dynamics AX 2009 Installation Guide 61 страница.
Windows SDK for Windows Server 2008 and .NET Framework 3.5
Download the Windows SDK for Windows Server 2008 and .NET
Framework 3.5
from the Microsoft Download Center.
Note:
You must install this SDK regardless of your operating system.
When installing the SDK, install the .NET Development Tools. The other components in the SDK are not required.
После инсталляции этого, все равно надо .NET SDK x64 ?
Старый 20.04.2009, 15:23   #13
soin is offline
soin
Ну что можно сказать: отчеты я развернул. были незначительные предупреждения
Ситуация следующая:
1) Отчеты в RoleCenter не работают:
1.1) например в узле продаж пишется что отчет smmSalesReports не найден. его кстати действительно на репорт-сервере нет.
1.2) В узле "финансы" например пишет "Ошибка служб Reporting Services". Произошла ошибка при обработке отчета. (rsProcessingAborted)
Пока установил AnalisisServices и запустил обновление кубов.
Думаю что делать с репортингом...
Старый 20.04.2009, 15:30   #14
soin is offline
soin
Сообщение от soin Посмотреть сообщение
Запустил ReportBuilder - и попробовал посмотреть список отчетов им - все отчеты присутствуют...
При открытии отчета при помощи ReportBuilder - выдает окно:
Невозможно открыть этот элемент. Данный отчет не может быть открыт в построителе отчетов. Server data sources do not match RDL
Последний раз редактировалось soin; 20.04.2009 в 15:34.
Старый 20.04.2009, 17:52   #15
soin is offline
soin
В общем переразвернул заново отчеты.
Теперь все.
Однако развертывание прошло как-то некорректно.
При открыти отчета через репорт-сервер в браузере отчет открывается с той же ошибкой что и в RoleCenter
Старый 21.04.2009, 11:56   #16
soin is offline
soin
https://mbs.microsoft.com/Cms/Templa...PrintPage=true
За это сообщение автора поблагодарили: Poleax (1), Dima_Dima (1).
Старый 21.04.2009, 17:29   #17
soin is offline
soin
все - победил...
Старый 22.04.2009, 10:45   #18
Poleax is offline
Poleax
Аватар для Poleax
Записей в блоге: 34
soin, если кратко, что надо было сделать чего нет к примеру в стандартной документации? (Microsoft Dynamics AX 2009 Installation Guide, SSRS and SSAS Integration for Microsoft Dynamics AX 2009)
На сколько все сложно, много подводных камней?
Аналогичные темы появляются на форуме и в инете. Пример: Ax2009 Instalation error т.е. RS самый проблематичный получается.
Последний раз редактировалось Poleax; 22.04.2009 в 10:56. Причина: темы на форуме
За это сообщение автора поблагодарили: Lemming (4).
Старый 22.04.2009, 16:32   #19
soin is offline
soin
Я не все в RS победил. Например в сравнении с VPC отчетов меньше. Но может так и должно быть. С другой стороны ряд отчетов не работает: например KPI по проектам, бюджет план/факт по проектам. Причина явно в самом отчете. Ошибка типа значение массива за границей массива
Старый 03.07.2009, 11:02   #20
miklenew is offline
miklenew
Аватар для miklenew
1,688 / 433 (18) +++++++
Форумчане, помогите кто может.
Чё там по ссылке то.
Доступа нет.
installation, ax2009, reporting services
msdynamicsax: Make the role centers work with Reporting Services Blog bot DAX Blogs 0 15.08.2008 11:05
gatesasbait: Installing Reporting Services, Analysis Services and Enterprise Portal for AX 2009 Blog bot DAX Blogs 0 03.07.2008 02:05
Arijit Basu: Microsoft SQL Server Reporting Services Integration Blog bot DAX Blogs 0 20.07.2007 11:50
casperkamal: SQL Reporting Services for Dynamics Ax 4.0 Blog bot DAX Blogs 0 12.03.2007 21:30
Часовой пояс GMT +3, время: 15:31.
