Старый 01.09.2024, 14:28   #1
25,558 / 848 (80) +++++++
alirazazaidi: How write a simple dialog for input In D365 Finance and Operations X++
Источник: https://www.tech.alirazazaidi.com/ho...log-for-input/
What a difference between RunBase and RunBaseBatch.
RunBase is used to create dialog. While runBaseBatch can be used to set dialog box as batch job.
Today I have a simple tip. that help you to create a input box to get values. this class will create a dialog box. You can use this to replace your runable class logic.
class RequestCopyJob extends RunBase
DialogField fieldInvoice;
DialogField fieldName;
// Variables to store user input
CustomerInvoiceId _InvoiceId;
// pack() and unpack() methods are used to load the last value from user
// for our simple example we are not going to use them.
public container pack()
return conNull();
public boolean unpack(container packedClass)
return true;
public Object dialog()
Dialog dialog = super();
// Set a title for dialog
dialog.caption( ‘Simple Dialog’);
// Add a new field to Dialog
fieldInvoice = dialog.addField(extendedTypeStr(DSACustomerInvoiceId), ‘Invoice’);
return dialog;
public boolean getFromDialog()
_InvoiceId = fieldInvoice.value();
return super();
public void run()
// Set Dialog field value to find CustTable
EInvoiceServiceRequests _EInvoiceServiceRequest;
select forupdate * from _EInvoiceServiceRequest where _EInvoiceServiceRequest.CustomerInvoiceId ==_InvoiceId;
ttsbegin;
_EInvoiceServiceRequest.ResponseStatus = Agz_KSA_CT_ServiceStatus::SUCCESS;
_EInvoiceServiceRequest.update();
ttscommit;
public static void main(Args _args)
RequestCopyJob Job = new RequestCopyJob();
// Prompt the dialog, if user clicks in OK it returns true
if (Job.prompt())
Job.run();
alirazazaidi: How To Use Advanced Filter: D365 Finance and Operations Blog bot DAX Blogs 0 20.06.2024 15:11
alirazazaidi: Consignment Inventory Handling in D365 Finance and Operations Blog bot DAX Blogs 0 20.01.2024 19:04
alirazazaidi: How to set any Field mandatory without writing code in D365 Finance and Operations. Blog bot DAX Blogs 0 12.02.2023 02:27
alirazazaidi: How to use Customer Template In D365 Finance and Operations Blog bot DAX Blogs 0 29.03.2021 00:25
alirazazaidi: Parent child form Customization D365 for Finance and Operations Blog bot DAX Blogs 0 21.01.2018 16:14
Часовой пояс GMT +3, время: 14:56.
