Старый 07.11.2024, 19:11   #1
25,643 / 848 (80) +++++++
atinkerersnotebook: Unofficial Demo Database Deployment Cheat Sheet
Источник: https://atinkerersnotebook.com/2024/...t-cheat-sheet/
Creating a local virtual machine (VM) for Dynamics 365 Finance & Operations (F&O) or Supply Chain Management (SCM) can be a highly valuable setup for testing and development. Here’s a step-by-step guide to building and configuring a new VM using a demo database.
Step 1: Building a 10.0.39 VM
  1. Download the Archive Files: Begin by downloading the 10.0.39 version archive files from Microsoft’s Lifecycle Services (LCS).
  2. Extract the Files: After downloading, extract the files to a designated location on your system.
  3. Create a Virtual Hard Disk (VHD): Using Hyper-V Manager, create a new VHD for the VM. For optimal performance, allocate as much memory as possible (32,868MB is recommended for smoother operations).
  4. Start the VM: Once the VM is set up and configured, boot it up to initiate the virtual environment.
Step 2: Extend the VM License
  1. Rearm the VM: Open the Command Prompt as an Administrator and enter the following command:
    slmgr /rearm
    This will extend the licensing period for the VM.
  2. Reboot the VM: After rearming, restart the VM to apply the license extension.
Step 3: Configure Security and Admin User
  1. Create a Signed Certificate: Run the certificate creation batch file to establish a signed certificate for secure communications.
  2. Provision an Admin User: Execute the Admin User Provisioning Tool located at:
    C:\AOSService\PackagesLocalDirectory\bin\AdminUserProvisioning.exe
    This tool configures an administrator account for access and system management.
  3. Start the Azure Storage Emulator: Launch the Azure Storage Emulator to enable necessary storage for F&O operations.
  4. Test F&O with the Default Database: At this point, verify that the F&O environment runs smoothly with the default database. This ensures the VM setup is correctly configured before moving on to the demo database replacement.
Step 4: Replace the Demo Database
  1. Open SQL Server Management Studio (SSMS): Connect to the SQL Server instance where your F&O database is hosted.
  2. Replace the AXdb Database: Within SSMS, replace the existing AXdb database with the new demo database. This will refresh your VM with a demo environment suitable for testing.
  3. Re-run the Admin User Provisioning Tool: After updating the database, run the Admin User Provisioning Tool once more to ensure the admin settings apply to the new database configuration.
Summary
Congratulations! You’ve successfully set up a new local VM with the Dynamics 365 F&O demo database. This environment is now ready for testing and development, providing a robust local setup that can emulate a production or sandbox environment.
atinkerersnotebook: Configuring a BYODB and Creating a Full and Incremental Entity Export Blog bot DAX Blogs 0 25.05.2018 15:11
atinkerersnotebook: Creating a Contact Registration App for Dynamics using PowerApps Blog bot DAX Blogs 0 25.08.2016 22:11
atinkerersnotebook: Using Vendor Requests to Manage On-boarding New Vendors Blog bot DAX Blogs 1 22.10.2013 02:24
atinkerersnotebook: Using PowerPivot to Analyze Dynamics AX Data Blog bot DAX Blogs 1 05.10.2013 07:23
atinkerersnotebook: Using Service Management to Track Service Orders Blog bot DAX Blogs 1 25.08.2013 19:16
Часовой пояс GMT +3, время: 18:19.
