Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 23.10.2013, 11:58   #1
ist is offline
ist
Hi Alex,
The problem is the xml message I mean. I have made screenshots.
1. The child table class instance is set to null
2. The child table class instance is not set to null.
The second case have TestServiceLine section <TestServiceLine class="entity"> without action.
The exception is:
I found a bunch of examples regarding AIF update operation which updates the parent table only, and without set child instances to null. I can't run this examples without mentioned exception.
Regards,
dynamics-community.at: Dynamics AX 2009 Rollup Update 6 released Blog bot DAX auf Deutsch 0 17.11.2010 18:11
emeadaxsupport: What changes are required if we change the Business Connector Proxy used by AX 2009 Generated AIF Web services Blog bot DAX Blogs 0 29.03.2010 15:05
Часовой пояс GMT +3, время: 02:54.
